Date/Time: Thu, 02 May 2024 00:42:37 +0000
CBOE/CFE bitcoin futures ticker
View Count: 1901
[2017-12-11 13:59:50] |
unset |
Could you please tell me what is the ticker for the CBOE/CFE bitcoin futures with Interactive Brokers? I have it on the IB platform but can't find it on SC. Thanks. |
[2017-12-11 17:59:46] |
This will be set up later today. For market data for now you can use the symbol XBTUSD-BMEX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 13:22:24] |
unset |
Is the ticker ready? It's for trading not watching. Thank you.
[2017-12-12 18:03:42] |
This has now been added and is listed in File >> Find Symbol >> Futures. The symbol begins with GXBT. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 19:57:34] |
unset |
Thanks. Working for historical, not intraday. Should I post the log?
[2017-12-12 20:08:36] |
Go ahead. We are also not sure about the exchange part of the symbol. It could just be that it needs to be CFE. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 21:18:51] |
unset |
Actually loading intraday just says "GXBT-20180100-CFECRYPTO-USD-1 5 Min #1 | Reloading chart. | 2017-12-12 16:17:36 GXBT-20180100-CFECRYPTO-USD-1 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: R:\Sierra Data\Sierra Data IB\GXBT-20180100-CFECRYPTO-USD-1.scid | 2017-12-12 16:17:36" |
[2017-12-12 21:32:33] |
unset |
Expiration dates are listed incorrectly that's why the intraday's don't work. e.g. GXBT-20180117-CFECRYPTO-USD-1 works intraday and historical e.g. GXBT-20180100-CFECRYPTO-USD-1 which is the one listed on SC works historical only |
[2017-12-12 22:42:37] |
OK, so unfortunately, the week has to be specified as well. We still have to develop a solution to that. Actually we did not even realize, that there were the extra characters in the pattern for the week. But that does make sense because we copied the volatility index futures pattern as a reference. Does this symbol work?: GXBT-201801-CFECRYPTO-USD-1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-18 18:37:21] |
oulous - Posts: 5 |
I am using GXBT-20180200-CFECRYPTO-USD-1. My chart is not updating in real time. I enabled CFE data at IB and the IB trade window is showing real time updates for GCBT. Invalid field #541. I have the latest SC just downloaded it. Message from IB: No historical data query found for ticker id:14. IB Error Code: 366. Request ID: 14. | 2018-01-18 13:31:18 Socket (15) | Socket gracefully closed by remote side. | 2018-01-18 13:31:18 Socket (15) | Closed. | 2018-01-18 13:31:18 GXBT-20180200-CFECRYPTO-USD-1 #1 | Reloading chart. | 2018-01-18 13:31:20 |
[2018-01-18 20:27:59] |
In TWS check for the exact expiration date. The last two zeros here: 20180200, need to be a particular day most likely. Here are the instructions to change the symbol of the chart: Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-07 09:20:04
[2018-02-07 18:27:44] |
Let us know if you need any further help with this.
[2018-03-12 14:07:08] |
User287992 - Posts: 51 |
It seems that those last 2 numbers are number for wednesday in third week of month (given that weekend starts on sunday) because I have tested following symbols that works with intraday data: GXBT-20180314-CFECRYPTO-USD-1 GXBT-20180418-CFECRYPTO-USD-1 + GXBT-20180117-CFECRYPTO-USD-1 from above |
