Date/Time: Mon, 06 May 2024 05:25:36 +0000
Gemini BTC Exchange
View Count: 1198
[2017-12-11 07:09:13] |
User82853 - Posts: 13 |
Currently looking at Gemini BTC Exchange. Will this be supported in the future? Also, is any information as to what bitcoin exchanges will or will not be (ie. not feasible) supported by SC? Thanks. |
[2017-12-11 10:06:39] |
Also would it be possible to pull market data only (not depth but just L1 data or last traded price) from the various exchanges? GDAX, Gemini, Kraken.
[2017-12-11 18:15:10] |
We will be adding market data support and trading support for more exchanges. Market data support is the easiest so it should not be a problem to do this. We cannot say when we will have this done though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
