Date/Time: Sun, 28 Apr 2024 10:23:31 +0000
Bitcoin symbol
View Count: 1804
[2017-12-10 16:39:42] |
User472677 - Posts: 316 |
What symbol works in SC to get a historical chart of bitcoin. Is it in SC historian feed? What else do I need to get a chart of bitcoin |
[2017-12-11 06:26:56] |
Best symbol to use is XBTUSD-BMEX. For complete documentation refer to: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-11 06:27:08
[2017-12-11 17:59:18] |
Thx. This is not working. Fo I need to be on a particular feed mentioned in your documentation? Also with Ib what symbol for new xbt contract on cboe |
[2017-12-11 18:35:01] |
Install a separate and current version of Sierra Chart as documented here: Using Multiple Data and Trading Services at the Same Time Use the default Service (SC Data-All Services) and use that symbol. The CBOE symbol for Interactive Brokers will be added later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-11 18:41:47
