Date/Time: Sat, 04 May 2024 15:20:17 +0000
Symbol subscription management
View Count: 676
[2017-12-10 10:52:53] |
Usermb - Posts: 126 |
Since I have also subscribed to US Equities data feed I have a problem with the Symbol Limits that cannot efficiently be solved by getting a higher limit overall since it doesn't scale that well and at custom 500+ it's both overkill and expensive. I actually do not need to be subscribed to real time data for all of these symbols, nor do I need the level 2 data so I already switched to "Use Low Bandwidth..." option in DTS for my swing instance. I have multiple SC instances open with 100's of chart windows for: - various single (not [C]) futures contracts - options on futures contracts Although I need the intraday tick data, I do not need real time data for them. An update once an hour would suffice. For options even once every 4 hours would do it. I experimented with Chart/Quote Board update intervals, it doesn't help. 1. What really happens when I have a SC instance with 200 charts open for 200 different futures symbols and my limit is at 70 futures symbols? 2. Is there any way I could tell SC not to be subscribed RT to some symbols? I am very grateful for your service, and since I do not really need the RT data, you would also benefit from lower load. |
[2017-12-10 20:54:42] |
Set up a separate instance for the charts you do not want real-time data for and uncheck Global Settings >>Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds. You can control the chart historical data download interval as explained here: Sierra Chart Historical Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-10 20:54:58
