Date/Time: Sun, 28 Apr 2024 12:48:33 +0000
Write Bar and Study Data To File Problem (no additional ZigZag info)
View Count: 1284
[2017-12-08 21:33:49] |
User132748 - Posts: 159 |
The study 'Write Bar and Study Data To File' has stopped saving full ZigZag info with 'Additional Output for Spreadsheets' set to YES. It was working fine for long time but now it writes only standard Zigzag fields (for example no "ZigZag length" field now).
[2017-12-09 21:52:43] |
We will check on this. Do you have the Include Hidden Studies Input with that study set to Yes? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-09 21:52:48
[2017-12-11 13:51:29] |
Thanks. Yes I did.
[2017-12-11 17:57:43] |
In the next release the study will have a Include Hidden Subgraphs Input. You will need to set that to Yes.
[2017-12-20 09:36:30] |
Unfortunately still no zigzag extra columns written to file. Running on 1669 build. "Write Bar and Study Data To File" with Hidden Studies = YES and Hidden Subgraphs = YES and with ZIGZAG "Additional Output for Spreadsheets" = YES writes only standard ZIGZAG data, no additional ZIGZAG columns. All worked well till about 1610 build. |
[2017-12-22 11:31:26] |
Any chance to solve this problem? Thanks
[2017-12-22 19:51:04] |
We are solving this now.
[2017-12-22 20:05:16] |
This is now solved. We are going to be putting out version 1675 later today.
[2018-01-02 01:15:41] |
Unfortunately problem is still not resolved. Write Bar/Study Data study doesn't write additional ZigZag study values. There are zigzag's column headers in the file but no data. 1678 build.
[2018-01-02 19:22:40] |
This is definitively resolved. Here is an example of the data: Date, Time, Open, High, Low, Last, Volume, OpenInt, OHLC Avg, HLC Avg, HL Avg, Bid Volume, Ask Volume, Zig Zag, Text Labels, Reversal Price, Zig Zag Line Length, Zig Zag Num Bars, Zig Zag Mid-Point, Extension Lines, Zig Zag Oscillator 2017/12/1, 00:00:00.0, 154.40, 155.02, 152.91, 154.76, 5567800, 0, 154.27, 154.23, 153.96, 0, 0, 152.91, 0.00, 152.91, -1.50, 1.00, 153.66, 0.00, 1.85 2017/12/4, 00:00:00.0, 155.67, 156.80, 155.07, 156.46, 4664300, 0, 156.00, 156.11, 155.93, 0, 0, 156.80, 0.00, 156.80, 3.89, 1.00, 154.86, 0.00, -0.34 2017/12/5, 00:00:00.0, 156.45, 156.74, 154.68, 155.35, 5068000, 0, 155.80, 155.59, 155.71, 0, 0, 154.68, 0.00, 154.68, -2.12, 1.00, 155.74, 0.00, 0.67 2017/12/6, 00:00:00.0, 155.69, 156.22, 154.09, 154.10, 3410700, 0, 155.02, 154.80, 155.15, 0, 0, 156.22, 0.00, 156.22, 1.54, 1.00, 155.45, 0.00, -2.12 2017/12/7, 00:00:00.0, 154.03, 154.45, 153.26, 153.57, 3771400, 0, 153.83, 153.76, 153.85, 0, 0, 153.26, 0.00, 153.26, -2.96, 1.00, 154.74, 0.00, 0.31 2017/12/8, 00:00:00.0, 153.94, 155.03, 153.55, 154.81, 3520200, 0, 154.33, 154.46, 154.29, 0, 0, 154.79, 0.00, 0.00, 0.00, 0.00, 155.55, 0.00, 1.55 2017/12/11, 00:00:00.0, 154.97, 155.89, 154.57, 155.41, 4102700, 0, 155.21, 155.29, 155.23, 0, 0, 156.32, 0.00, 0.00, 0.00, 0.00, 155.55, 0.00, 2.15 2017/12/12, 00:00:00.0, 155.20, 157.85, 155.16, 156.74, 6321800, 0, 156.24, 156.58, 156.51, 0, 0, 157.85, 0.00, 157.85, 4.59, 3.00, 155.55, 0.00, -1.11 2017/12/13, 00:00:00.0, 156.60, 156.73, 153.89, 153.91, 5661600, 0, 155.28, 154.84, 155.31, 0, 0, 153.89, 0.00, 153.89, -3.96, 1.00, 155.87, 0.00, 0.02 2017/12/14, 00:00:00.0, 154.60, 155.11, 153.70, 154.00, 4637400, 0, 154.35, 154.27, 154.40, 0, 0, 155.11, 0.00, 155.11, 1.22, 1.00, 154.50, 0.00, -1.11 2017/12/15, 00:00:00.0, 153.61, 153.80, 152.03, 152.50, 11279800, 0, 152.99, 152.78, 152.92, 0, 0, 152.03, 0.00, 152.03, -3.08, 1.00, 153.57, 0.00, 0.47 2017/12/18, 00:00:00.0, 153.59, 154.18, 153.21, 153.33, 5092800, 0, 153.58, 153.57, 153.70, 0, 0, 154.18, 0.00, 154.18, 2.15, 1.00, 153.10, 0.00, -0.85 2017/12/19, 00:00:00.0, 154.05, 154.17, 153.09, 153.23, 4116400, 0, 153.63, 153.50, 153.63, 0, 0, 153.09, 0.00, 153.09, -1.09, 1.00, 153.63, 0.00, 0.14 2017/12/20, 00:00:00.0, 153.65, 153.89, 152.78, 152.95, 3785600, 0, 153.32, 153.21, 153.33, 0, 0, 153.89, 0.00, 153.89, 0.80, 1.00, 153.49, 0.00, -0.94 2017/12/21, 00:00:00.0, 153.17, 153.46, 151.49, 151.50, 4153900, 0, 152.40, 152.15, 152.48, 0, 0, 151.49, 0.00, 151.49, -2.40, 1.00, 152.69, 0.00, 0.01 2017/12/22, 00:00:00.0, 151.82, 153.00, 151.50, 152.50, 2990500, 0, 152.21, 152.33, 152.25, 0, 0, 152.68, 0.00, 0.00, 0.00, 0.00, 152.68, 0.00, 1.01 2017/12/26, 00:00:00.0, 152.51, 153.86, 152.50, 152.83, 2479000, 0, 152.93, 153.06, 153.18, 0, 0, 153.86, 0.00, 153.86, 2.37, 2.00, 152.68, 0.00, -1.03 2017/12/27, 00:00:00.0, 152.95, 153.18, 152.61, 153.13, 2149200, 0, 152.97, 152.97, 152.89, 0, 0, 152.61, 0.00, 152.61, -1.25, 1.00, 153.24, 0.00, 0.52 2017/12/28, 00:00:00.0, 153.20, 154.12, 153.20, 154.04, 2687600, 0, 153.64, 153.79, 153.66, 0, 0, 153.67, 0.00, 0.00, 0.00, 0.00, 153.67, 0.00, 1.43 2017/12/29, 00:00:00.0, 154.17, 154.72, 153.41, 153.42, 3327000, 0, 153.93, 153.85, 154.07, 0, 0, 154.72, 0.00, 154.72, 2.11, 2.00, 153.67, 0.00, -1.30 If you still have a problem, provide us a Chartbook with only one chart, and only these two studies and we will look at it. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-02 19:23:53
[2018-01-02 22:54:34] |
Chartbook attached. Thank you
Private File |
[2018-01-03 04:58:01] |
This is what we see using your Chartbook for the most recent Zig Zag Length: Date, Time, Open, High, Low, Last, Volume, # of Trades, OHLC Avg, HLC Avg, HL Avg, Bid Volume, Ask Volume, Zig Zag, Text Labels, Reversal Price, Zig Zag Line Length, Zig Zag Num Bars, Zig Zag Mid-Point, Extension Lines, Zig Zag Oscillator 2018/1/2, 18:09:45.1, 2692.50, 2693.50, 2692.25, 2693.50, 3270, 1240, 2692.94, 2693.08, 2692.88, 1597, 1673, 2692.25, 0.00, 2692.25, -2.00, 2.00, 2693.25, 0.00, 1.25 Chart: http://www.sierrachart.com/image.php?Image=1514955290338.png The -2 in bold is the 8 tick Length. In case you do not have the latest changes, update to the latest "Prerelease" following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-04 10:25:43] |
Yes it finally works fine on 1681 prerelease. Thank you
