Date/Time: Thu, 02 May 2024 10:40:15 +0000
Gold IB
View Count: 744
[2017-12-07 21:21:07] |
User336946 - Posts: 37 |
Hi. I'm having a weird issue. If you add the Initial Balance study to Gold, it works if you put say, 08:00:00 - 09:00:00. If you put 07:20:00 - 08:20:00 it doesn't show up at all.
[2017-12-07 21:25:49] |
What is the timeframe of the chart bars?
[2017-12-07 21:30:07] |
I've tried 5min and 15min. I do see them for yesterday's session, just not todays. It's the same setup I use on other symbols (just different times).
[2017-12-07 21:32:04] |
I figured it out. For some reason I was missing data. Delete/redownload fixed it.
