Date/Time: Fri, 03 May 2024 02:55:17 +0000
Market Depth Historical Graph
View Count: 701
[2017-12-07 16:20:53] |
User134797 - Posts: 52 |
Hi all, How can I change/modify the line thickness of the Market Depth Historical Graph. By some chart the Market Depth Historical Graph line thickness and text are readable other not. Regards, Iwan |
[2017-12-07 18:34:08] |
There are no lines with the Market Depth Historical Graph study. Only background shading. For the chart where you see what you are describing, post an image of it by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
