Date/Time: Sat, 27 Apr 2024 21:23:39 +0000
Chartbook problems
View Count: 1271
[2017-12-07 15:16:35] |
User447007 - Posts: 39 |
Hi, For the last 7 days I have continous problems with chartbooks. If the the chartbook had say 20 charts and I would open it, it only shows 10-12. After I restart sierra the issue is the same, sometimes shows even fewer chart than earlier say 9-10. I never experienced that issue earlier, but the last 7-10 days it is a constant problem. Please help, |
[2017-12-07 18:24:36] |
Update to the current version of Sierra Chart following these instructions here: Software Download: Fast Update If you still have a problem, provide a copy of the Message Log following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog What operating system version are you running? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-07 18:45:52] |
I use XP on my tradestation as my multi monitor videocards work with xp only unfortunately. Until I haven't updated sierra for months it was fine, but I haven't got live data for some symbol, so I updated the current version. I see no Message Log since last upgrade, as the whole messagelog window is black. Did you improve something which is not working with xp? May be I could use an older version of sierra, could you send me a link for a version of 2016 to download? |
[2017-12-07 18:54:31] |
so I updated the current version. I see no Message Log since last upgrade, as the whole messagelog window is black. Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows If you want to go back to a prior version, here are the instructions: Software Download: Software Rollback Procedure You can find what particular version matches with what date here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-07 18:55:09
[2017-12-07 20:06:03] |
Ok thank you. I noticed that 3-4 larger cryptocurrencies (dshusd, xmrusd,zecusd, are not operating in your list. Is there any possibility that they would give data, at least end of day in the near future? |
[2017-12-08 17:45:32] |
From what particular crypto currency exchange are you referring to?
[2017-12-08 18:17:35] |
Bitfinex, when I use SC Data - All Services
[2017-12-08 18:39:28] |
We expect these will become available in about 2 weeks.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-08 18:39:37
