Date/Time: Mon, 29 Apr 2024 23:23:20 +0000
Simple Question. How to enable "Time Remaining" in the chart information bar.
View Count: 794
[2017-12-07 00:16:53] |
Mooshu22 - Posts: 25 |
I am looking for the setting to enable the Time Remaining count down in the chart information bar. For example it shows up as TR: 5m 30s. I have it enabled in one instance of Sierra Charts but created an additional instance of Sierra Charts and can't find the setting to re-enable it. I've looked everywhere I could think to look, must just be overlooking it somewhere. Thanks-
[2017-12-07 04:18:23] |
This is through Global Settings >> Customize Chart Header: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-07 04:32:43] |
SOLUTION: Global Settings >> Customize Chart Header >> Move Up - Bar Countdown to the top. It was there just couldn't see it in a narrow window.
