Date/Time: Sat, 27 Apr 2024 18:08:53 +0000
Market Manipulation?
View Count: 837
[2017-12-06 18:35:56] |
Crtfyd - Posts: 277 |
Is this market manipulation by the market makers, or just a coincidental blip in the data? The attached screen pic shows data went out for the noted times. Ironically at a pivot and the same prices. I edit/downloaded data an hour later and it filled it in. A lot of volume was at that time. I wouldn't say that the chart couldn't handle the volume bc other bars have volume like that. (ie:the open) My chart data download in milliseconds is 38. I know that's low, but using 1 sec charts I usually don't experience a lag. And it doesn't appear here that's the issue. Thx http://www.sierrachart.com/image.php?Image=1512584416476.png |
[2017-12-06 18:56:03] |
For the best data feed use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed You will not miss any data with it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 18:56:10
