Date/Time: Sun, 28 Apr 2024 03:41:40 +0000
Market Statistics do not update
View Count: 1002
[2017-12-06 15:56:43] |
User328799 - Posts: 1 |
Hello. All of my data works expect for the market statistics. The YM-Tick, for example, loads but then does nothing. I'm at a loss as to what to do.
[2017-12-06 17:21:04] |
The symbol is TICK-YM Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
