Date/Time: Sat, 27 Apr 2024 05:49:31 +0000
Iaccurate mid
View Count: 802
[2017-12-06 11:19:26] |
User97684 - Posts: 136 |
Hi, Pls help - the mid calculation is giving incorrect readingds in my observation. A few times before I have noticed it. PLs see attached pics. The calculation gives a value of 11 851.75, where as the mid in light blue is at 11853.5 ish... Thanks a lot for help, best ves |
inaccurate__mid_1.png / V - Attached On 2017-12-06 11:16:31 UTC - Size: 144.55 KB - 314 views mid_study_2.png / V - Attached On 2017-12-06 11:16:36 UTC - Size: 147.11 KB - 262 views study_settings_mid_inaccurate_3.png / V - Attached On 2017-12-06 11:16:40 UTC - Size: 146.32 KB - 260 views |
[2017-12-06 18:27:55] |
First, that chart is too complex for us to make any sense of it. You should realize that. Here are the instructions to post an image of the chart: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image The Mid - HL Average calculation is simply the average of the High and Low of the Daily OHLC study. You can verify that by using the Chart Values tool to see all of these values for the Daily OHLC study: http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-06 22:57:46] |
Thanks, sorry my bad, there is nothing wrong with the mid , it is working correctly. (I was not taking the high of the day, but the high of that particular swing).
