Date/Time: Sun, 28 Apr 2024 14:06:21 +0000
TPo - sun + mon
View Count: 1024
[2017-12-06 06:59:05] |
EuropeanTrader - Posts: 290 |
Hi, pls see attached. How can I combine Sunday and Monday profile data automatically or by default? Thank you! |
AUDNZD [M] #23 2017-12-06 07_57_39.427.png / V - Attached On 2017-12-06 06:59:00 UTC - Size: 77.25 KB - 302 views |
[2017-12-06 18:38:58] |
This section here explains this: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php#UnderstandingTradingDayDatesBasedOnSessionTimes You need to use reversed Session Times. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-07 08:02:09] |
Thank you but I dont understand this at all. What shall I input so that I get this done? Forex 24 markets, no evening session needed, right now I have 00:00:00 - 23:59:59 Thank you for your assistance, I appreciate it |
[2017-12-07 09:05:09] |
For the Session Times in Chart >> Chart Settings. Use the following: Start Time: 17:00:00 End Time: 16:59:59 The documentation we linked to provides background information about this. Here is more information: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php#WhyReverseSessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-07 09:05:26
