Date/Time: Sun, 28 Apr 2024 21:02:11 +0000
Time zone
View Count: 1077
[2017-12-05 23:35:56] |
2garin - Posts: 184 |
How to choose the right time zone?
Private File Private File |
[2017-12-06 00:13:21] |
We understand. We need to resolve a problem with that custom setting control. We will have that out in about a day. However, if you just simply enter 12 in the UTC Offset box that will do what you want. We are also going to add a USD +12 time zone that you can just directly select from the list. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 00:13:40
[2017-12-06 00:22:12] |
I can not post in the UTC Offset box +12We are also going to add a USD +12 time zone that you can just directly select from the list.
This setting is shown in the screenshot.
Date Time Of Last Edit: 2017-12-06 00:28:55
Private File |
[2017-12-06 00:39:10] |
Just wait for us to have the new version out in a day or two and that new UTC +12 setting will be there.
[2017-12-06 18:53:01] |
We have released version 1660 with the new UTC +12 Time Zone setting. Update to the latest "Prerelease": Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 19:43:43
[2017-12-06 19:43:23] |
Actually, the version we want you to update to is 1660. We were mistaken. It is not 1659.
[2017-12-06 22:25:26] |
File attached
[2017-12-07 00:03:17] |
This will be solved in the next release.
