Date/Time: Thu, 02 May 2024 09:22:38 +0000
Spreadsheets not saving
View Count: 686
[2017-12-05 21:20:17] |
User104854 - Posts: 441 |
I've created a few spreadsheets lately and when I restart the program and the spreadsheet pulls up all of the columns that I edited are blank. I've never had an issue with this until recently. I always save everything religiously. I just created a new simple spreadsheet, added a few things to the columns, saved and reloaded it, and everything was blank. Why does this happen and what do I need to do in order to make sure that all of my work is saved????? I can't have it disappear like this. Thanks.
[2017-12-05 21:55:00] |
This is an issue in 1658 only. It has been resolved. Update to version 1659 following these instructions: Software Download: Fast Update There are also backups of spreadsheets in the Backups subfolder in the folder Sierra Chart installed to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
