Date/Time: Mon, 29 Apr 2024 01:53:17 +0000
Indicator for "Grid" lines
View Count: 1043
[2017-12-05 20:51:30] |
Bitboy - Posts: 13 |
Hello, I need an indicator that creates a grid between 2 points ( a and b ). In the inserted chart I used a Fibonacci Price Projection, but it would be better as a study .. For example, my point is A is a low and point B is the high, this area should be split into 25% fields. And also on the downside should be the grid... aso you can see! The 2 indicator is similar, for example the opening price is 2000 i want a grid of 0.25% from this price ... (2000 * 0.0025) = 5 points, so every 5 points up or down should be a horizontal line. is this possible? Or what is the best solution for this http://www.sierrachart.com/image.php?Image=1512506380341.png kind regards |
[2017-12-06 18:46:31] |
You just need to use one of these drawing tools here: http://www.sierrachart.com/index.php?page=doc/Tools.html#RetracementExpansionProjection See if the Horizontal Grid is helpful as well: http://www.sierrachart.com/index.php?page=doc/ChartMenu.html#HorizontalGrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 18:47:10
