Date/Time: Mon, 29 Apr 2024 08:02:39 +0000
Number Bars Filters
View Count: 1106
[2017-12-05 20:09:08] |
User28914 - Posts: 87 |
I have a client that is trying to use the Volume Filter on his Number Bars but it's not projecting the filter properly. I cannot duplicate this on my charts, so I am not sure if there is a setting overriding the volume filter. It should only be showing volume over 200, also, if he duplicate this chart, all his #'s are different on the duplication. Thoughts? Works fine on mine, so wondering if there is a setting that is messing his up. |
pastedImage.png / V - Attached On 2017-12-05 20:09:03 UTC - Size: 368.73 KB - 318 views |
[2017-12-06 03:37:44] |
Must be because the Intraday Data Storage Time Unit is not set to 1 Tick. This is explained here: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
