Date/Time: Sun, 13 Jul 2025 07:21:43 +0000
Stochastic Values
View Count: 1858
[2013-09-16 14:00:41] |
infpz - Posts: 826 |
Hello, Can the stochastic values be displayed as shown on the attachment? (not on the Y Axis, but rather the places where the line turns) Thanks, PZ |
[2013-09-16 19:57:04] |
Yes. We will get back to you on this later today.
[2013-09-17 00:34:47] |
The capability for this will be supported in the next release. Although it is not exactly what you are looking for but as close as we can reasonably get it: http://www.sierrachart.com/image.php?l=1379377846708.png There will be a new draw style called Value of Subgraph that you can use. In this image, we have 2 stochastic studies in the chart region so you can also see the normal line as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-17 11:11:55] |
Looks great, thanks.
[2013-09-17 11:23:17] |
There is actually a way to do exactly as the image shows by using the Color Bar Based on Alert Condition by writing a formula which checks for the change in direction of the stochastic line. And set it to output the Stochastic value at the chart columns where this is true. By using the Value of Subgraph, you will then get the display that you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-17 11:23:46
[2013-09-17 11:55:19] |
I can try this but new draw style would be preferred from a support perspective.
[2013-09-18 05:56:39] |
1026 with the new Draw Style has been released. What we meant in our prior posting is that the new draw style Value of Subgraph in combination with the Color Bar Based on Alert Condition can give you the exact same result as shown in the original image you posted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-23 18:52:49] |
Refer to the description for Value of Subgraph here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
