Date/Time: Thu, 02 May 2024 19:34:49 +0000
Numbers Bar Study - the same setting, different outcome
View Count: 1059
[2017-12-05 15:36:29] |
Bluefruit - Posts: 41 |
Hi, I have installed current version of Sierra Chart (v1658). Unfortunatelly the visual outcome of the Numbers Bar Study applied to the chart looks different to the previous version of Sierra Chart (v1562) I used. Please see attached visuals. I havenĀ“t changed any settings. How to make it look like in v1562 again. Thanks a lot, P. Date Time Of Last Edit: 2017-12-05 16:29:07
Numbers Bar_SierraChart_v1562.png / V - Attached On 2017-12-05 15:35:35 UTC - Size: 137.59 KB - 375 views Numbers Bar_SierraChart_v1658.png / V - Attached On 2017-12-05 15:35:39 UTC - Size: 113.22 KB - 312 views Numbers Bar Study Settings Comparison.pdf - Attached On 2017-12-05 16:28:54 UTC - Size: 760.42 KB - 311 views |
[2017-12-05 18:39:28] |
John - SC Support - Posts: 31328 |
There was a change to this particular coloring for the Numbers Bars in version 1641. You can see the information on what changed here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1641 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-08 13:05:42] |
User43540 - Posts: 6 |
Hi, is it posible to create new coloring method "Based on Diagonal (NonDominant Side) AskVol BidVol Percentage" (with coloring possibility on both diagonal sides)? It will be helpful for lot of people. Thanks K. |
[2017-12-08 14:30:30] |
I agree, Thx. P.
[2017-12-08 18:07:32] |
We will add this.
