Date/Time: Sun, 28 Apr 2024 14:14:11 +0000
[Programming Help] - trading system ?
View Count: 869
[2017-12-04 23:38:25] |
zippyzip - Posts: 293 |
trying out new study on trading system crossover , is there a way to have it enter next trade as it exits on that signal so if it short and the exit signal is a long and it trigger a long ? thanks
[2017-12-05 02:21:53] |
Yes this would be performing a reversal. Refer to: Automated Trading Management: SupportReversals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-05 12:52:04] |
thank you , can you tell me where to turn that feature on , i dont see it on the options for the study
[2017-12-05 18:49:52] |
Are you using ACSIL for the trading system? Or the Spreadsheet System for Trading study. Or how is that this trading system is implemented? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-06 02:57:19] |
im talking about the new study you added called trading system - study sub graph crossover . i can only get it to trade one direction at a crossover and it only exits at crossover dosent reenter
[2017-12-06 09:29:09] |
When there is an existing Position, when there is a crossover, it is only going to do an exit if the Exit on Crossover When in Position Input is set to Yes. It would require another crossover to do an entry. We tested the trading system and it does go both long and short. Any further help will have to be paid development help. What you are looking for is just not within the scope of our support. It can be available at 80 USD per hour. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 09:30:00
[2017-12-07 05:06:15] |
In the next release this trading system study will support reversals.
