Date/Time: Thu, 02 May 2024 20:48:19 +0000
Offline documentation
View Count: 1154
[2017-12-04 20:15:41] |
User13668 - Posts: 291 |
Can you refresh/update the version for download - currently looks like it is about mid October. Cheers |
[2017-12-04 21:55:18] |
We will check on this. It should be up-to-date .
[2017-12-04 22:11:50] |
The problem has been corrected. We will be updating the content today. For reference, this is what you are referring to: https://www.sierrachart.com/downloads/SierraChartDocumentation.zip Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-04 22:43:18] |
Re post #3 "For reference, this is what you are referring to:" Correct. When I downloaded the zip and opened it the main folder 'www.sierrachart' had a last modified date of mid October so I asssumed this meant the documentation would only be current as at that date. I could not see any other way of determining how up to date the offline documentation was/is. |
[2017-12-05 01:06:01] |
That documentation should be up-to-date now.
