Date/Time: Mon, 29 Apr 2024 04:04:58 +0000
[Programming Help] - Single bar painting
View Count: 1943
[2017-12-04 18:22:01] |
SithTrader - Posts: 6 |
Sierra Support, I'm having difficulty coding a single bar being painted, and could use some help. If you would take a look at the link, you'll see what I'm trying to accomplish: http://www.sierrachart.com/image.php?Image=1512410850433.png Currently, when I use the color bar based on alert condition, my problem is that it's painting all of the bars in a direction after the Kiwi's Trailing Stop reverses. How would I code: singling out the first down candle after a pullback on a short Kiwi reverse? Also, how would I code: singling out the first up candle after a pullback on a long Kiwi reverse? Thank you. |
bandicam 2017-12-04 11-59-26-065.png / V - Attached On 2017-12-04 17:59:51 UTC - Size: 125.65 KB - 623 views |
[2017-12-06 11:02:05] |
Refer to: Study/Chart Alerts And Scanning: ** Support Policy For Alert Condition Formula Programming Help ** Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
