Date/Time: Mon, 29 Apr 2024 17:15:31 +0000
minor issue since update to 1656
View Count: 830
[2017-12-04 12:31:37] |
michelh - Posts: 159 |
Hi Sierra, I run 2 instances of SC small issue since the update - The status bar no longer appears in the toolbar for instance 1. The toolbar in instance 2 is working. I double checked in customize the toolbar and it is definitely there but doesn't show. removing and then adding again doesn't fix. The status bar in instance 2 works fine. With thanks, M Date Time Of Last Edit: 2017-12-04 12:43:28
[2017-12-04 19:07:10] |
Refer to the documentation here for this: Control Bar: Control Bar Button or Item Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
