Date/Time: Thu, 02 May 2024 10:15:40 +0000
drop on trailing stop
View Count: 1113
[2017-12-04 01:11:45] |
User845611 - Posts: 13 |
If I have a position on, I can simply drop a stop or limit behind it. I find no way to drop in a trailing stop. If there is a way please let me know how. If there is no way, there should be a way and may I request you enable this. It should not be required to fiddle around in the chart trade window to place a trailing stop any more than it is to drop a stop on the chart. I hope to get a nice surprise that it is there or please could you make be there.
[2017-12-04 03:24:07] |
The best way is to use the chart trading feature to submit the Trailing Stop. Here is the documentation: Chart Trading and the Chart DOM: Entering Orders From the Chart It will have to be added to the menu as the documentation explains. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
