Date/Time: Sun, 05 May 2024 19:51:06 +0000
Futures Symbol Rollover
View Count: 1357
[2013-09-16 09:25:49] |
Veronika Skrehotova - Posts: 8 |
Hello, I try to rollover intraday chart by using "Perform Futures Symbol Rollover" and I heave following problem. The option "Join Previous Data" is disabled although I have disabled the Chart >> Chart Settings >> Continuous Futures Contract option. I attached printscreen. Please, how can I enable the option "Join Previous Data". Thank you for your advice. Veronika Skrehotova |
Symbol rollover.docx - Attached On 2013-09-16 09:21:55 UTC - Size: 99.76 KB - 449 views |
[2013-09-16 10:19:28] |
Update Sierra Chart to the latest release by selecting Help >> Download Prerelease.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-16 16:21:10
[2013-09-16 11:44:15] |
I´ve just done it but the problem haven´t disappeared.
[2013-09-16 16:26:28] |
Not sure what the problem is. The Join option is available and can be enabled when we run a test. For now use the Continuous Futures Contract feature: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
