Date/Time: Mon, 29 Apr 2024 15:14:09 +0000
Issue with BitMex testnet integration
View Count: 1458
[2017-12-02 17:42:31] |
User856720 - Posts: 1 |
Hi Support, I have created API key / secret pair at BitMex Testnet. However I do not have a clue on integrating BitMex Testnet with Sierra Chart tool. I have installed latest version of Sierra Chart (1656). I have gone through help links on this forum, nothing helped. THanks Ajay K |
[2017-12-02 19:19:36] |
Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
