Date/Time: Mon, 29 Apr 2024 00:51:19 +0000
Candle measureming by ticks/points
View Count: 1184
[2017-12-02 12:45:52] |
User33743 - Posts: 83 |
Hi, Is available on sierra study that shows size of drawing candle in ticks or points? |
[2017-12-02 19:06:02] |
Yes this can be done by using the Bar Difference study: Bar Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-04 11:43:24] |
Would you be kind to show me how i can setup this indicator to show LAST CANDLE SIZE IN TICKS so i would see this e.g TEXT "15TIKS" etc. ?
[2017-12-04 18:58:15] |
To do that, requires that you also use this study: Text Display For Study You also need to set the Input Calculate Difference in Ticks Input to Yes with the Bar Difference study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-04 18:59:05
[2017-12-05 12:08:03] |
Thank you! That is working. Is is possible to add also counting by points?
