Date/Time: Wed, 01 May 2024 23:32:11 +0000
Reply jump not working correctly
View Count: 814
[2017-12-02 11:02:32] |
User264108 - Posts: 1 |
During market replay I use jump "by time" with "unit" set to 23:00:00.000 .... but it moves charts just about 10 minutes instead of 23 hours, why is that? Used on NQ emini, range bar standard 6 ticks Date Time Of Last Edit: 2017-12-02 11:06:49
[2017-12-04 10:41:57] |
There is a particular scenario why this potentially can happen. But it would not consistently happen. We do have that scenario resolved. For now uncheck Skip Empty Periods on the Replay control panel.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-04 10:42:04
