Date/Time: Fri, 03 May 2024 08:41:55 +0000
Hided window disapears again when switching between chartbooks
View Count: 795
[2017-12-01 21:16:44] |
User889191 - Posts: 61 |
I hided a window and can only make it visible again by clicking attach/detach in Windows and Chartbooks. When I switch to another chartbook and switch back it is again not visible. Strange is that it is blank in Windows and Chartbooks(see attachment). I think in Windows and Chartbooks it is better if I can double-click on window to make it visible again.
WindowsAndChartbooks.png / V - Attached On 2017-12-01 21:15:07 UTC - Size: 24.83 KB - 259 views |
[2017-12-01 23:36:00] |
That is not the documented procedure to restore a hidden window. The documented procedure is here: Window and CW Menus: Hide Window (Window) We will need to add support for what you are doing. That is not currently supported. It is not surprising there can be some odd behavior related to that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-02 13:01:03] |
O.k Thanks for clarification. I was to stupid to find the CW Menu !!
[2017-12-02 18:54:27] |
The latest prerelease does resolve this issue. But we have not done thorough testing.
