Date/Time: Thu, 02 May 2024 18:32:40 +0000
Most recent upgrade to current version 1656
View Count: 690
[2017-12-01 12:49:05] |
sbeltran - Posts: 8 |
on Wednesday I upgraded to the current version of Sierra Charts (1656) only to find that ALL of my Renko Chart are a mess. None of the Renko bricks align with the horizontal grid any more. My question and hope is, are you able to tell me what my version of Sierra Chart was before I did the upgrade so I may go back the that version when everything was working correctly. If not is there a version you could recommend? I did reload version 1641 to no avail. Thanks Best Regardes |
[2017-12-01 14:50:54] |
Refer to the section here about Renko bar alignment: Renko Bar Charts: Opening Price for First Renko Bar and Alignment (Aligned Renko Bars) You need to change the Bar Period Type to Aligned Renko. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-01 18:41:19
