Date/Time: Sun, 28 Apr 2024 21:13:20 +0000
Draw tool for vertical line with time stamp
View Count: 1336
[2013-09-15 21:16:39] |
Willson - Posts: 176 |
Can't find a tool to show a vertical line with time text at top. Want to mark a chart with the line wherever I click. Help appreciated. I am sure it's in SC, just can't find it Regards |
[2013-09-17 05:32:04] |
This is fully supported with the Vertical Line tool: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#VerticalandHorizontalLines Through the configuration/properties window for that tool you can enable Date and Time labels. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
