Date/Time: Thu, 02 May 2024 11:17:04 +0000
Same VP different data
View Count: 936
[2017-11-30 08:46:05] |
User33743 - Posts: 83 |
Hi, Would you be kind to check why on two same VP I get VPOC on different level? How to prevent that kind of situation? |
Screenshot_1.png / V - Attached On 2017-11-30 08:45:52 UTC - Size: 69.88 KB - 297 views Screenshot_2.png / V - Attached On 2017-11-30 08:45:57 UTC - Size: 101.56 KB - 313 views |
[2017-11-30 09:35:08] |
Refer to: Volume By Price Study: Volume Profile Differences This is for you to analyze. Analyzing this is not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-30 11:36:18] |
Sure, TY!
