Date/Time: Mon, 29 Apr 2024 10:02:41 +0000
CandleStick Alert
View Count: 1535
[2017-11-30 08:46:02] |
User371906 - Posts: 141 |
Hello, Is there a way to have an audio or better yet chart color (background or column) of color to alert for a breaking candle (candle passing another candle)? Please advice Thanks Gio |
[2017-11-30 09:35:43] |
Refer to this page: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-30 17:11:17] |
Afternoon, Unfortunately I was unable after reading this page and many others to come up with the code to write the candle breaking (passing another candle) with screen screen column color alert. =CROSSOVER(BAR>??PREVIOUS BAR??) Do you have a code for this that perhaps is a bit similar so I can try to modify it for this purpose? Much appreciative for help. Please let me know Regards Gio |
[2017-11-30 18:49:38] |
This is vague, but we would think it would be as simple as this: OR(H > H[-1], L < L[-1]) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-30 19:50:12] |
Very Thankful, Worked like a charm. Kudos... |
