Date/Time: Fri, 03 May 2024 14:31:55 +0000
how to becktest longer period
View Count: 878
[2017-11-29 22:18:07] |
User30743 - Posts: 364 |
hi have a problem with "out of mememory" mistake message when trying to load a chart for backtest. i use a custom timeframe with is derived from one trade timeframe, so it cannot load more than lets say 30 days. but i would like to becktest 100 days. how should i split it? or ho will i set it up that i need to load a particular range (i thought that is it in main settings in the chart but it doesnt work) so how do i do it? |
Screenshot_2.png / V - Attached On 2017-11-29 22:18:00 UTC - Size: 62.15 KB - 284 views |
[2017-11-30 18:02:36] |
You can use these Chart Settings for this: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo The settings you highlighted are the wrong ones. The ones you need are right below. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-30 18:03:04
