Date/Time: Wed, 08 May 2024 10:08:30 +0000
Chart Grid / Chart setup
View Count: 1802
[2013-09-15 16:39:07] |
User14682 - Posts: 83 |
When I go into Graphics setting and try to set up the chart grid nothing happens??? Any ideas?
[2013-09-15 17:24:36] |
M5amhan - Posts: 468 |
if you are using the chart>graphics settings you need to uncheck "use global graphics settings..." at the top, if you are using global settings>graphics settings you need to leave it checked and it should work
[2013-09-15 17:30:18] |
Its unchecked???
[2013-09-15 17:38:28] |
i have no idea.. make sure chart>vertical grid and chart>horizontal grid>all regions is checked as well |
[2013-09-15 17:48:15] |
Nice Thanks
[2013-09-16 01:41:50] |
Here is the documentation for chart Grid Lines: https://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#grid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
