Date/Time: Mon, 06 May 2024 10:39:48 +0000
Sierra chart error while opening and saving
View Count: 853
[2017-11-29 16:34:11] |
User466737 - Posts: 22 |
Getting the following error while opening and saving in sierrachart - "Failed to open the configuration file when saving. configuration not saved. Error. Windows Error code 5. Access is denied." Tried reinstalling in the same directory as per your reinstall instructions, but still get this error. Any help appreciated. -S |
[2017-11-29 17:17:09] |
Refer to this page for help with this: http://www.sierrachart.com/index.php?page=doc/helpdetails16.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
