Date/Time: Mon, 29 Apr 2024 09:18:56 +0000
Flatten and reverse buttons won't work
View Count: 1386
[2017-11-29 00:09:00] |
User764597 - Posts: 4 |
When trying to use these functions in sierra charts the buttons seem to be disabled. I am in a position and I am not able to close out when hitting the flatten button. See screenshot for reference.
Attachment Deleted. Sierra error.jpg / V - Attached On 2017-11-29 00:08:33 UTC - Size: 189.86 KB - 292 views |
[2017-11-29 04:41:53] |
Apparently you have disabled both the Flatten and Reverse buttons. Refer to: Global Trade Settings Windows: Flatten (Global Settings >> Chart Trade Settings >> General >> Display Trade Window Controls) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-29 13:55:26] |
Thank you. I can not find the "CANCEL ALL" button to enable. Please advise. Thanks again. |
[2017-11-29 18:45:48] |
The Cancel All button cannot be disabled.
