Date/Time: Sat, 27 Apr 2024 17:43:01 +0000
[Programming Help] - Bollinger Band Breakout
View Count: 1701
[2017-11-28 23:05:46] |
User509820 - Posts: 69 |
Hello, is there a way to draw a arrow under/above a initial candle that breaks outside the opposite side of a BB? Thanks in advanced!
[2017-11-29 04:42:27] |
Yes use this particular study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-29 06:46:07] |
Here I have uploaded an example. Any time price closes outside the BB on the opposite side a arrow forms. Is this possible?
Date Time Of Last Edit: 2017-11-29 06:47:09
Screen Shot 2017-11-28 at 10.44.45 PM.png / V - Attached On 2017-11-29 06:45:33 UTC - Size: 55.24 KB - 535 views |
[2017-11-30 15:35:40] |
Is this possible?
[2017-12-04 04:52:56] |
[2017-12-04 18:12:14] |
Yes for sure this is supported. There are many examples here to help you with this: Study/Chart Alerts And Scanning: Alert Formula Examples Refer to examples 28, 33 and 34. These are all good examples and the formulas can be used as is with the Bollinger Bands study. These are the specific instructions to follow: Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-04 18:27:28
[2017-12-04 18:27:35] |
The prior post has been updated.
