Date/Time: Tue, 07 May 2024 11:38:09 +0000
How to change datafeed when downloading chart templete
View Count: 1117
[2013-09-15 06:28:01] |
User93560 - Posts: 1 |
Hi I have downloaded a chart templete, which uses IQfeed, but I use OEC. How can I get the charts to work? |
[2013-09-15 22:51:11] |
You need to change the symbol of the charts: http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
