Date/Time: Sun, 28 Apr 2024 23:57:07 +0000
Alert Manager Columns Spacing Changes
View Count: 668
[2017-11-28 15:50:12] |
samual sprat - Posts: 343 |
Hi, When I have the alert manager window open, by default the 'Source' Column is far too wide for my monitor. So to save scrolling to the right to see alert text I tried to reduce the Source column width. But when I do this it stays narrower for a couple of seconds then moves back to being too wide again. I've checked the contents of the source column and none of the text in there is as wide as the column, so not sure why it keeps getting widened. Thanks Sunny Date Time Of Last Edit: 2017-11-28 17:20:09
[2017-11-28 17:21:02] |
Please ignore. I just saw the "Auto Set Alert Text Column Width" option
[2017-11-28 17:48:36] |
It is the "Alert Text" field itself which is getting wider.
