Date/Time: Fri, 03 May 2024 01:05:39 +0000
Displaying the daily range in ticks at the top of each volume profiles
View Count: 935
[2017-11-28 11:33:21] |
s291117 - Posts: 28 |
Hello Support, I would like to display the range at the top of each daily volume profil. I have tried this option: text diplay from studies based on number bars calculated value : daily range then text diplay for studies, setting and inputs, study and subgraph to display : ID(numbers bars calculated value).SG(daily range) I have added the Number bars to the volumes Profiles chart and then called the parameter Daily range from the NBARS study. The problem is that i do not succeed to display the daily range in ticks at the top of each volume and that I do not want the Nbars to appear. Can you help me on this matter please ? See attached. PS: i am also searching to visualise the global previous weekly range, global previous monthly range, the daily average range according to a custom period, on any chart. Is this possible ? Thanks ! |
Attachment Deleted. _MP_Daily_TPO-VOL_NBARS.StdyCollct - Attached On 2017-11-28 11:30:10 UTC - Size: 232.63 KB - 284 views |
[2017-11-28 18:51:55] |
The most we can help you is to recommend to use this study: Previous/Period OHLC-Variable Period You can then calculate the difference between the high and low lines using this study: Study Subgraphs Subtract/Difference And have a look at this study as well: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-28 18:52:16
