Date/Time: Sat, 27 Apr 2024 05:44:37 +0000
Time Exit (Flatten on time)
View Count: 2016
[2017-11-27 16:30:43] |
User952297 - Posts: 5 |
Hello, i would like to know if you have a function which flattens (exits) all or certain positions at a defined time. Lets say i have a Long Mini DAX positions at friday but i want to close it by time automatically before the exchange closes to avoid holding overnight or over weekend. All the best! |
[2017-11-27 18:23:39] |
This can be accomplished by using the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-27 18:37:27] |
The only question is how exactly? :)
[2017-11-27 19:04:12] |
Xfanman1 - Posts: 320 |
Couldn't he use Global Profit Loss Management too? Global Profit/Loss Management Date Time Of Last Edit: 2017-11-27 19:05:34
[2017-11-27 19:52:42] |
The only question is how exactly? :) You will need to study the documentation for the Spreadsheet System for Trading study and use a formula to submit an order based upon time.However, the suggestion given in post #4 will be much easier but it applies to all current Trade Positions. So in that case, use the Global Profit/Loss Management feature: Global Profit/Loss Management Here is the specific section: Global Profit/Loss Management: Flatten Positions at Set Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-27 19:53:52
[2018-07-12 00:35:16] |
User109710 - Posts: 21 |
I using suggestions on the post 4 and flatten the position at set time by holding the open position with oco order. How do I check the final flatten price for the position? |
[2018-07-12 15:04:44] |
You can use the Trade Activity Log or, if Sierra Chart has not been closed, you could use the Orders and Positions Window. Refer to: Trade Activity Log and: Trading Information Windows: Trade Orders and Positions Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-12 15:32:00] |
I closed the SC after set the OCO order, anyways to see final exist price ? I do check all the things u suggested at above, can;t find it
Date Time Of Last Edit: 2018-07-12 15:33:33
[2018-07-13 13:02:48] |
The Trade Activity Log page linked above does discuss missing order fills. You should use the CTS low cost connection model so you do not miss any order fills: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-13 13:04:57
