Date/Time: Tue, 30 Apr 2024 23:09:49 +0000
Where does alerts file reside?
View Count: 1318
[2017-11-27 11:32:45] |
User953894 - Posts: 58 |
I probably overuse the alerts feature, and my alerts log gets large/long very fast. I'm wondering if there's a way to feed the file to a database for sorting but I don't see a file that is created. I see a log can be manually created, but I'm wondering if there's a way to access a file without the manual step.
[2017-11-27 17:55:08] |
There is no Alerts Log file.
[2017-11-27 20:44:54] |
Thank you. So is there no way to populate a list/database of recent alerts?
[2017-11-27 21:02:32] |
We could add the ability for the Alerts Log to be saved to a file. We will do that.
[2017-11-27 22:19:17] |
Wow, that's incredible! How long would it take for you to include that capability? THANKS! |
[2017-12-05 11:18:54] |
Not sure. Allow a few weeks.
[2018-09-26 23:56:44] |
Just following up. I see the option on the General Settings General 4 tab to write alerts to a log file. Where is this file located? |
[2018-09-27 14:09:35] |
John - SC Support - Posts: 31240 |
When the option to save the Alerts Log is selected, the Alerts Log file is saved in the Logs folder under the main Sierra Chart installation location. For example, with a typical installation, this would be located at C:\SierraChart\Logs and is named Alert Log[date time].log.
