Date/Time: Sat, 27 Apr 2024 08:40:18 +0000
Forex brokers?
View Count: 5611
[2017-11-27 11:29:55] |
User953894 - Posts: 58 |
I'm US based and use your FXCM forex data for analysis. I can't use FXCM for trading and I'm wondering which forex brokers allow/support Sierra Charts. It seems as though there aren't any, but I wanted to confirm that. Alternatively, is there a packaged "bridge" to MT4 for orders? Or is there a way to output orders created in SIM to an external system? Thanks! |
[2017-11-27 15:18:46] |
tradernikki - Posts: 41 |
You can use your FXCM Trading Station account to trade on SC FXCM Trading Service Another forex broker supported is LMAX LMAX Trading Service |
[2017-11-27 17:27:29] |
Thank you for listing those. Unfortunately, US residents are not allowed to trade with either of those brokers. Are there any US brokers that support Sierra Charts? I'm expecting that there are not any US brokers, so could you address my other questions (is there a packaged "bridge" to MT4 for orders? Or is there a way to output orders created in SIM to an external system?) Again, thanks! |
[2017-11-27 17:42:26] |
(is there a packaged "bridge" to MT4 for orders? Or is there a way to output orders created in SIM to an external system?) Know, and this is not something we would help with anyway because it would not be reliable.
[2017-11-27 18:22:31] |
You could use Gain Capital for Forex trading: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php We really recommend trading Forex futures instead. It is going to be more reliable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-13 17:29:33] |
bwalks123 - Posts: 122 |
So if I sign up and fund a Forex.com (Gain Capital) account I will be able to use those credentials with SierraChart correct, and what is the account min to trade using SierraChart/Forex.com(Gain Capital)? Also, do you support server oco forex.com orders, wanting to clarify that if I open account with Forex.com that my oco orders will fill even when SierraChart is closed. Thanks |
[2017-12-13 21:00:55] |
No you will not be able to. We also know nothing about account minimums. The account would have to be with Gain Capital futures which also supports Forex trading. Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php Server-side OCO orders are supported with Gain Capital. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
