Date/Time: Thu, 02 May 2024 01:49:28 +0000
DYZ17 (Dax) data feed is not working
View Count: 701
[2017-11-27 10:42:02] |
stephangrassl - Posts: 1 |
Hi! I just downloaded the demo of sierra chart and tried to see the DAX feed, which is not working.(so the chart is loaded, but the last minutes are missing and it is not updated, level 2 data do not work either) Forex is working. Please help Best regards |
Attachment Deleted. Private File |
[2017-11-27 10:43:46] |
If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-27 10:44:27
