Date/Time: Wed, 08 May 2024 21:54:28 +0000
More rollover...
View Count: 1362
[2013-09-14 15:34:58] |
pismo10 - Posts: 158 |
Using @ESZ13 [C] on Ver 1019 with Cont Futures Ctc box checked in Chart Settings. It is rolling over on Friday morning. How do I get it to rollover on Thursday morning instead? Thanks |
[2013-09-14 19:59:20] |
Switched to @ES# so using DTNIQ data rather than letting Sierra try to figure it out. Seems to work better. Unchecked everything..This yields unadjusted data that flips to the new ctc on Thursday morning. It also does not take 5 minutes to reload data.
Date Time Of Last Edit: 2013-09-14 20:07:09
[2013-09-16 20:01:01] |
This is good. Longer-term, we do plan improvements with the Continuous Futures Contract feature which will dramatically improve the loading times and also perform rollover based upon calendar rules rather than volume.
