Date/Time: Sun, 04 Oct 2026 14:02:34 +0000
Chart data missing
View Count: 1389
| [2017-11-27 09:42:05] |
| User106180 - Posts: 88 |
Hi. I'm missing data for some Intraday Charts. Link for screenshot of one of the problem charts, you will notice that it is missing data from 7/7 to 11/27 - http://www.sierrachart.com/image.php?Image=1511775465614.png Also attached screenshot of 'Global Data/Trade Service Settings'. I have tried doing the following things several times: - Right click on chart, select 'Edit/Download Data - Intraday Chart' - Right click on chart, select 'Delete and Download Datta' - Edit -> Edit/Download Data - Intraday Chart - Edit -> Delete All Data And Download - Edit -> Reload and Recalculate - Edit -> Reload Intraday Charts In the following post I will paste the Message Log. I'm sure I'm making some simple mistake. Thank you in advance for your help. |
| [2017-11-27 09:42:34] |
Reading Internal Order ID file. | 2017-11-27 07:56:17 Reading Trade Orders file. | 2017-11-27 07:56:17 Reading Trade Positions file. | 2017-11-27 07:56:17 Listening on UDP port 22904. | 2017-11-27 07:56:17 Software version: 1652 | 2017-11-27 07:56:17 Usage end date: 2017-12-08 | 2017-11-27 07:56:17 Enabled for: Advanced Features. | 2017-11-27 07:56:17 Enabled for: Advanced Features 2. | 2017-11-27 07:56:17 Enabled for: Sierra Chart Historical Data Service. | 2017-11-27 07:56:17 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-11-27 07:56:17 Current selected Data/Trading service: SC Data - All Services | 2017-11-27 07:56:17 Chart Update Interval: 10 | 2017-11-27 07:56:17 Time Zone: +00:00:00 (UTC+00) | 2017-11-27 07:56:17 2017-11-27 18:56:21 Local computer time | 2017-11-27 07:56:17 2017-11-27 07:56:21 Local computer time in UTC | 2017-11-27 07:56:17 2017-11-27 07:56:21 Local computer time in SC Time Zone | 2017-11-27 07:56:17 2017-11-27 07:56:20 Server time in UTC | 2017-11-27 07:56:17 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-11-27 07:56:17 Program path: C:\SierraChart\ | 2017-11-27 07:56:17 Data Files path: C:\SierraChart\Data\ | 2017-11-27 07:56:17 OS Version Number: 10.0 | 2017-11-27 07:56:17 Locale Setting: C | 2017-11-27 07:56:17 Checking for new symbol settings for service code scdataallservices | 2017-11-27 07:56:17 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-11-27 07:56:17 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-11-27 07:56:17 Received 5 login tokens. | 2017-11-27 07:56:22 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-11-27 07:56:23 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-11-27 07:56:23 Symbol settings are up-to-date for scdataallservices | 2017-11-27 07:56:26 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-11-27 07:56:27 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-11-27 07:56:27 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-11-27 07:56:27 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-27 07:56:27 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-11-27 07:56:27 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-11-27 07:56:29 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-11-27 07:56:29 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-11-27 07:56:29 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-27 07:56:29 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-11-27 07:56:29 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-11-27 07:56:31 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-11-27 07:56:31 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-11-27 07:56:31 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-27 07:56:31 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-11-27 07:56:31 SC Data - All Services | Connected to data server. | 2017-11-27 07:56:32 AUDCAD 5 Min #1 | Reloading chart. | 2017-11-27 07:57:23 AUDCHF 60 Min #2 | Reloading chart. | 2017-11-27 07:57:23 AUDJPY 60 Min #3 | Reloading chart. | 2017-11-27 07:57:23 AUDNZD 60 Min #4 | Reloading chart. | 2017-11-27 07:57:23 AUDUSD 5 Min #5 | Reloading chart. | 2017-11-27 07:57:23 CADCHF 5 Min #6 | Reloading chart. | 2017-11-27 07:57:23 CADJPY 5 Min #7 | Reloading chart. | 2017-11-27 07:57:23 CHFJPY 5 Min #8 | Reloading chart. | 2017-11-27 07:57:23 EURAUD 5 Min #9 | Reloading chart. | 2017-11-27 07:57:23 EURCAD 5 Min #10 | Reloading chart. | 2017-11-27 07:57:23 EURAUD 5 Min #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2017-11-23 10:20:00. Next Bar Date Time: 2017-11-23 10:10:00. Filename: EURAUD.scid | 2017-11-27 07:57:23 EURCHF 5 Min #11 | Reloading chart. | 2017-11-27 07:57:23 EURGBP 5 Min #12 | Reloading chart. | 2017-11-27 07:57:23 EURJPY 5 Min #13 | Reloading chart. | 2017-11-27 07:57:23 EURNZD 5 Min #14 | Reloading chart. | 2017-11-27 07:57:23 EURUSD 5 Min #15 | Reloading chart. | 2017-11-27 07:57:23 GBPAUD 5 Min #16 | Reloading chart. | 2017-11-27 07:57:23 GBPCAD 5 Min #17 | Reloading chart. | 2017-11-27 07:57:23 GBPCHF 5 Min #18 | Reloading chart. | 2017-11-27 07:57:23 GBPJPY 5 Min #19 | Reloading chart. | 2017-11-27 07:57:23 GBPNZD 5 Min #20 | Reloading chart. | 2017-11-27 07:57:23 GBPUSD 5 Min #21 | Reloading chart. | 2017-11-27 07:57:23 NZDCAD 5 Min #22 | Reloading chart. | 2017-11-27 07:57:23 NZDCHF 5 Min #23 | Reloading chart. | 2017-11-27 07:57:23 NZDJPY 5 Min #24 | Reloading chart. | 2017-11-27 07:57:23 NZDUSD 5 Min #25 | Reloading chart. | 2017-11-27 07:57:23 USDCAD 5 Min #26 | Reloading chart. | 2017-11-27 07:57:23 USDCHF 5 Min #27 | Reloading chart. | 2017-11-27 07:57:23 USDJPY 5 Min #28 | Reloading chart. | 2017-11-27 07:57:23 Using Bid/Ask average for last trade price for AUDCAD | 2017-11-27 07:57:23 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDCAD. ID: 1 | 2017-11-27 07:57:23 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-11-27 07:57:23 DTC Client socket (6) | Creating socket. | 2017-11-27 07:57:23 DTC Client socket (6) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:23 SC DTC Data with Market Depth | Requesting security definition data for: AUDCAD. ID: 1 | 2017-11-27 07:57:23 Intraday data recording state for symbol AUDCAD is set to download 'Pending'. | 2017-11-27 07:57:23 Delaying start of download for AUDCAD | 2017-11-27 07:57:23 Using Bid/Ask average for last trade price for AUDCHF | 2017-11-27 07:57:23 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDCHF. ID: 2 | 2017-11-27 07:57:23 SC DTC Data with Market Depth | Requesting security definition data for: AUDCHF. ID: 2 | 2017-11-27 07:57:23 Intraday data recording state for symbol AUDCHF is set to download 'Pending'. | 2017-11-27 07:57:23 Using Bid/Ask average for last trade price for AUDJPY | 2017-11-27 07:57:23 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDJPY. ID: 3 | 2017-11-27 07:57:23 SC DTC Data with Market Depth | Requesting security definition data for: AUDJPY. ID: 3 | 2017-11-27 07:57:23 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-11-27 07:57:23 Using Bid/Ask average for last trade price for AUDNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDNZD. ID: 4 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: AUDNZD. ID: 4 | 2017-11-27 07:57:28 Intraday data recording state for symbol AUDNZD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for AUDUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 5 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 5 | 2017-11-27 07:57:28 Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for CADCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: CADCHF. ID: 6 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: CADCHF. ID: 6 | 2017-11-27 07:57:28 Intraday data recording state for symbol CADCHF is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for CADJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: CADJPY. ID: 7 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: CADJPY. ID: 7 | 2017-11-27 07:57:28 Intraday data recording state for symbol CADJPY is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for CHFJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: CHFJPY. ID: 8 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: CHFJPY. ID: 8 | 2017-11-27 07:57:28 Intraday data recording state for symbol CHFJPY is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for EURAUD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURAUD. ID: 9 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: EURAUD. ID: 9 | 2017-11-27 07:57:28 Intraday data recording state for symbol EURAUD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for EURCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURCAD. ID: 10 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: EURCAD. ID: 10 | 2017-11-27 07:57:28 Intraday data recording state for symbol EURCAD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for EURCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURCHF. ID: 11 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: EURCHF. ID: 11 | 2017-11-27 07:57:28 Intraday data recording state for symbol EURCHF is set to download 'Pending'. | 2017-11-27 07:57:28 HD Request # 2 | Downloading Intraday chart data for AUDCAD to the file AUDCAD.scid. Service: fxcm | 2017-11-27 07:57:28 HD Request # 2 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:28 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:28 Socket (7) | Creating socket. | 2017-11-27 07:57:28 Socket (7) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for EURGBP | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURGBP. ID: 12 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: EURGBP. ID: 12 | 2017-11-27 07:57:28 Intraday data recording state for symbol EURGBP is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for EURJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURJPY. ID: 13 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: EURJPY. ID: 13 | 2017-11-27 07:57:28 Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for EURNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURNZD. ID: 14 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: EURNZD. ID: 14 | 2017-11-27 07:57:28 Intraday data recording state for symbol EURNZD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for EURUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 15 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 15 | 2017-11-27 07:57:28 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for GBPAUD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPAUD. ID: 16 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: GBPAUD. ID: 16 | 2017-11-27 07:57:28 Intraday data recording state for symbol GBPAUD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for GBPCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCAD. ID: 17 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: GBPCAD. ID: 17 | 2017-11-27 07:57:28 Intraday data recording state for symbol GBPCAD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for GBPCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCHF. ID: 18 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: GBPCHF. ID: 18 | 2017-11-27 07:57:28 Intraday data recording state for symbol GBPCHF is set to download 'Pending'. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Connected to server. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for GBPJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPJPY. ID: 19 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: GBPJPY. ID: 19 | 2017-11-27 07:57:28 Intraday data recording state for symbol GBPJPY is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for GBPNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPNZD. ID: 20 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: GBPNZD. ID: 20 | 2017-11-27 07:57:28 Intraday data recording state for symbol GBPNZD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for GBPUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 21 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 21 | 2017-11-27 07:57:28 Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for NZDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: NZDCAD. ID: 22 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: NZDCAD. ID: 22 | 2017-11-27 07:57:28 Intraday data recording state for symbol NZDCAD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for NZDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: NZDCHF. ID: 23 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: NZDCHF. ID: 23 | 2017-11-27 07:57:28 Intraday data recording state for symbol NZDCHF is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for NZDJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: NZDJPY. ID: 24 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: NZDJPY. ID: 24 | 2017-11-27 07:57:28 Intraday data recording state for symbol NZDJPY is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for NZDUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: NZDUSD. ID: 25 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: NZDUSD. ID: 25 | 2017-11-27 07:57:28 Intraday data recording state for symbol NZDUSD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for USDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: USDCAD. ID: 26 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: USDCAD. ID: 26 | 2017-11-27 07:57:28 Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for USDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: USDCHF. ID: 27 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: USDCHF. ID: 27 | 2017-11-27 07:57:28 Intraday data recording state for symbol USDCHF is set to download 'Pending'. | 2017-11-27 07:57:28 Using Bid/Ask average for last trade price for USDJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Starting real-time market data updates for: USDJPY. ID: 28 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Requesting security definition data for: USDJPY. ID: 28 | 2017-11-27 07:57:28 Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Sending logon request message. | 2017-11-27 07:57:28 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:28 HD Request # 2 | Sending historical data logon request message. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received logon response. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Successfully connected. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Trading is not supported. | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHFJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURAUD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURGBP | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPAUD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2017-11-27 07:57:28 HD Request # 2 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: AUDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol AUDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol AUDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol AUDJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol AUDNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol CADCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol CADJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol CHFJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol EURAUD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol EURCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol EURCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol EURGBP | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol EURJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol EURNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol GBPAUD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol GBPCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol GBPCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol GBPJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol GBPNZD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2017-11-27 07:57:28 HD Request # 2 | Decompressing data. | 2017-11-27 07:57:28 HD Request # 2 | Receiving Intraday data for AUDCAD starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:28 HD Request # 2 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:20 | 2017-11-27 07:57:28 Socket (7) | Initiating close of socket by core. | 2017-11-27 07:57:28 Socket (7) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:28 Historical data download thread signaled to stop. | 2017-11-27 07:57:28 HD Request # 2 | Received 297 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:24 (3.1 minutes) and wrote 296 records for AUDCAD | 2017-11-27 07:57:28 HD Request # 2 | Intraday download COMPLETE for AUDCAD. Completion time: 0s. Unique request ID: 1 | 2017-11-27 07:57:28 Removed historical data download ID 1 | 2017-11-27 07:57:28 Real-time Intraday chart data file updates started for AUDCAD | 2017-11-27 07:57:28 Intraday chart data file opened for AUDCAD | 2017-11-27 07:57:28 Delaying start of download for AUDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol NZDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol NZDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol NZDJPY | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol NZDUSD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol USDCAD | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol USDCHF | 2017-11-27 07:57:28 SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2017-11-27 07:57:28 Socket (7) | Socket gracefully closed by remote side. | 2017-11-27 07:57:29 Socket (7) | Closed. | 2017-11-27 07:57:29 Opened cached Intraday file: C:\SierraChart\Data\AUDCAD.scid | 2017-11-27 07:57:32 HD Request # 3 | Downloading Intraday chart data for AUDCHF to the file AUDCHF.scid. Service: fxcm | 2017-11-27 07:57:33 HD Request # 3 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:33 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:33 Socket (8) | Creating socket. | 2017-11-27 07:57:33 Socket (8) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:33 HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:33 HD Request # 3 | Sending historical data logon request message. | 2017-11-27 07:57:33 HD Request # 3 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: AUDCHF | 2017-11-27 07:57:34 HD Request # 3 | Decompressing data. | 2017-11-27 07:57:34 HD Request # 3 | Receiving Intraday data for AUDCHF starting at 2017-11-27 07:54:16 | 2017-11-27 07:57:34 HD Request # 3 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:20 | 2017-11-27 07:57:34 Socket (8) | Initiating close of socket by core. | 2017-11-27 07:57:34 Socket (8) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:34 Historical data download thread signaled to stop. | 2017-11-27 07:57:34 HD Request # 3 | Received 332 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:31 (3.2 minutes) and wrote 327 records for AUDCHF | 2017-11-27 07:57:34 HD Request # 3 | Intraday download COMPLETE for AUDCHF. Completion time: 1s. Unique request ID: 2 | 2017-11-27 07:57:34 Removed historical data download ID 2 | 2017-11-27 07:57:34 Real-time Intraday chart data file updates started for AUDCHF | 2017-11-27 07:57:34 Intraday chart data file opened for AUDCHF | 2017-11-27 07:57:34 HD Request # 4 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-11-27 07:57:34 HD Request # 4 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:57:34 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:34 Socket (9) | Creating socket. | 2017-11-27 07:57:34 Socket (9) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:34 Socket (8) | Socket gracefully closed by remote side. | 2017-11-27 07:57:34 Socket (8) | Closed. | 2017-11-27 07:57:34 HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:34 HD Request # 4 | Sending historical data logon request message. | 2017-11-27 07:57:34 HD Request # 4 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: AUDJPY | 2017-11-27 07:57:35 HD Request # 4 | Decompressing data. | 2017-11-27 07:57:35 HD Request # 4 | Receiving Intraday data for AUDJPY starting at 2017-11-27 07:54:17 | 2017-11-27 07:57:35 HD Request # 4 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:17 | 2017-11-27 07:57:35 Socket (9) | Initiating close of socket by core. | 2017-11-27 07:57:35 Socket (9) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:35 Historical data download thread signaled to stop. | 2017-11-27 07:57:35 HD Request # 4 | Received 413 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:32 (3.3 minutes) and wrote 411 records for AUDJPY | 2017-11-27 07:57:35 Added 1 Time and Sales records to Intraday data file for AUDJPY after download. | 2017-11-27 07:57:35 HD Request # 4 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 3 | 2017-11-27 07:57:35 Removed historical data download ID 3 | 2017-11-27 07:57:35 Real-time Intraday chart data file updates started for AUDJPY | 2017-11-27 07:57:35 Intraday chart data file opened for AUDJPY | 2017-11-27 07:57:35 HD Request # 5 | Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: fxcm | 2017-11-27 07:57:35 HD Request # 5 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:57:35 HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:35 Socket (10) | Creating socket. | 2017-11-27 07:57:35 Socket (10) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:35 Socket (9) | Socket gracefully closed by remote side. | 2017-11-27 07:57:35 Socket (9) | Closed. | 2017-11-27 07:57:35 HD Request # 5 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:35 HD Request # 5 | Sending historical data logon request message. | 2017-11-27 07:57:35 HD Request # 5 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: AUDNZD | 2017-11-27 07:57:36 HD Request # 5 | Decompressing data. | 2017-11-27 07:57:36 HD Request # 5 | Receiving Intraday data for AUDNZD starting at 2017-11-27 07:54:17 | 2017-11-27 07:57:36 HD Request # 5 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:19 | 2017-11-27 07:57:36 Socket (10) | Initiating close of socket by core. | 2017-11-27 07:57:36 Socket (10) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:36 Historical data download thread signaled to stop. | 2017-11-27 07:57:36 HD Request # 5 | Received 421 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:34 (3.3 minutes) and wrote 420 records for AUDNZD | 2017-11-27 07:57:36 Added 1 Time and Sales records to Intraday data file for AUDNZD after download. | 2017-11-27 07:57:36 HD Request # 5 | Intraday download COMPLETE for AUDNZD. Completion time: 0s. Unique request ID: 4 | 2017-11-27 07:57:36 Removed historical data download ID 4 | 2017-11-27 07:57:36 Real-time Intraday chart data file updates started for AUDNZD | 2017-11-27 07:57:36 Intraday chart data file opened for AUDNZD | 2017-11-27 07:57:36 HD Request # 6 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2017-11-27 07:57:36 HD Request # 6 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:57:36 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:36 Socket (11) | Creating socket. | 2017-11-27 07:57:36 Socket (11) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:36 Socket (10) | Socket gracefully closed by remote side. | 2017-11-27 07:57:36 Socket (10) | Closed. | 2017-11-27 07:57:36 HD Request # 6 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:37 HD Request # 6 | Sending historical data logon request message. | 2017-11-27 07:57:37 HD Request # 6 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: AUDUSD | 2017-11-27 07:57:37 HD Request # 6 | Decompressing data. | 2017-11-27 07:57:37 HD Request # 6 | Receiving Intraday data for AUDUSD starting at 2017-11-27 07:54:17 | 2017-11-27 07:57:37 HD Request # 6 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:20 | 2017-11-27 07:57:37 Socket (11) | Initiating close of socket by core. | 2017-11-27 07:57:37 Socket (11) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:37 Historical data download thread signaled to stop. | 2017-11-27 07:57:37 HD Request # 6 | Received 515 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:32 (3.3 minutes) and wrote 514 records for AUDUSD | 2017-11-27 07:57:37 Added 3 Time and Sales records to Intraday data file for AUDUSD after download. | 2017-11-27 07:57:37 HD Request # 6 | Intraday download COMPLETE for AUDUSD. Completion time: 1s. Unique request ID: 5 | 2017-11-27 07:57:37 Removed historical data download ID 5 | 2017-11-27 07:57:37 Real-time Intraday chart data file updates started for AUDUSD | 2017-11-27 07:57:37 Intraday chart data file opened for AUDUSD | 2017-11-27 07:57:37 HD Request # 7 | Downloading Intraday chart data for CADCHF to the file CADCHF.scid. Service: fxcm | 2017-11-27 07:57:37 HD Request # 7 | Download start date-time: 2017-11-27 07:54:05.000 | 2017-11-27 07:57:37 HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:37 Socket (12) | Creating socket. | 2017-11-27 07:57:37 Socket (12) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:37 Socket (11) | Socket gracefully closed by remote side. | 2017-11-27 07:57:37 Socket (11) | Closed. | 2017-11-27 07:57:37 HD Request # 7 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:38 HD Request # 7 | Sending historical data logon request message. | 2017-11-27 07:57:38 HD Request # 7 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:05. Record interval: 0. Symbol: CADCHF | 2017-11-27 07:57:38 HD Request # 7 | Decompressing data. | 2017-11-27 07:57:38 HD Request # 7 | Receiving Intraday data for CADCHF starting at 2017-11-27 07:54:05 | 2017-11-27 07:57:38 HD Request # 7 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:20 | 2017-11-27 07:57:38 Socket (12) | Initiating close of socket by core. | 2017-11-27 07:57:38 Socket (12) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:38 Historical data download thread signaled to stop. | 2017-11-27 07:57:38 HD Request # 7 | Received 193 records from 2017-11-27 07:54:05 to 2017-11-27 07:57:36 (3.5 minutes) and wrote 192 records for CADCHF | 2017-11-27 07:57:38 Added 6 Time and Sales records to Intraday data file for CADCHF after download. | 2017-11-27 07:57:38 HD Request # 7 | Intraday download COMPLETE for CADCHF. Completion time: 0s. Unique request ID: 6 | 2017-11-27 07:57:38 Removed historical data download ID 6 | 2017-11-27 07:57:38 Real-time Intraday chart data file updates started for CADCHF | 2017-11-27 07:57:38 Intraday chart data file opened for CADCHF | 2017-11-27 07:57:38 HD Request # 8 | Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: fxcm | 2017-11-27 07:57:38 HD Request # 8 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:38 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:38 Socket (13) | Creating socket. | 2017-11-27 07:57:38 Socket (13) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:38 Socket (12) | Socket gracefully closed by remote side. | 2017-11-27 07:57:38 Socket (12) | Closed. | 2017-11-27 07:57:38 HD Request # 8 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:39 HD Request # 8 | Sending historical data logon request message. | 2017-11-27 07:57:39 HD Request # 8 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: CADJPY | 2017-11-27 07:57:39 HD Request # 8 | Decompressing data. | 2017-11-27 07:57:39 HD Request # 8 | Receiving Intraday data for CADJPY starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:39 HD Request # 8 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:20 | 2017-11-27 07:57:39 Socket (13) | Initiating close of socket by core. | 2017-11-27 07:57:39 Historical data download thread signaled to stop. | 2017-11-27 07:57:39 Socket (13) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:39 HD Request # 8 | Received 192 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:32 (3.2 minutes) and wrote 191 records for CADJPY | 2017-11-27 07:57:39 HD Request # 8 | Intraday download COMPLETE for CADJPY. Completion time: 1s. Unique request ID: 7 | 2017-11-27 07:57:39 Removed historical data download ID 7 | 2017-11-27 07:57:39 Real-time Intraday chart data file updates started for CADJPY | 2017-11-27 07:57:39 Intraday chart data file opened for CADJPY | 2017-11-27 07:57:39 HD Request # 9 | Downloading Intraday chart data for CHFJPY to the file CHFJPY.scid. Service: fxcm | 2017-11-27 07:57:39 HD Request # 9 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:39 HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:39 Socket (14) | Creating socket. | 2017-11-27 07:57:39 Socket (14) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:39 Socket (13) | Socket gracefully closed by remote side. | 2017-11-27 07:57:39 Socket (13) | Closed. | 2017-11-27 07:57:39 HD Request # 9 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:40 HD Request # 9 | Sending historical data logon request message. | 2017-11-27 07:57:40 HD Request # 9 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: CHFJPY | 2017-11-27 07:57:40 HD Request # 9 | Decompressing data. | 2017-11-27 07:57:40 HD Request # 9 | Receiving Intraday data for CHFJPY starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:40 HD Request # 9 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:40 Socket (14) | Initiating close of socket by core. | 2017-11-27 07:57:40 Socket (14) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:40 Historical data download thread signaled to stop. | 2017-11-27 07:57:40 HD Request # 9 | Received 285 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:36 (3.3 minutes) and wrote 284 records for CHFJPY | 2017-11-27 07:57:40 Added 1 Time and Sales records to Intraday data file for CHFJPY after download. | 2017-11-27 07:57:40 HD Request # 9 | Intraday download COMPLETE for CHFJPY. Completion time: 1s. Unique request ID: 8 | 2017-11-27 07:57:40 Removed historical data download ID 8 | 2017-11-27 07:57:40 Real-time Intraday chart data file updates started for CHFJPY | 2017-11-27 07:57:40 Intraday chart data file opened for CHFJPY | 2017-11-27 07:57:40 HD Request # 10 | Downloading Intraday chart data for EURAUD to the file EURAUD.scid. Service: fxcm | 2017-11-27 07:57:40 HD Request # 10 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:40 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:40 Socket (15) | Creating socket. | 2017-11-27 07:57:40 Socket (15) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:40 Socket (14) | Socket gracefully closed by remote side. | 2017-11-27 07:57:40 Socket (14) | Closed. | 2017-11-27 07:57:40 HD Request # 10 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:41 HD Request # 10 | Sending historical data logon request message. | 2017-11-27 07:57:41 HD Request # 10 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: EURAUD | 2017-11-27 07:57:41 HD Request # 10 | Decompressing data. | 2017-11-27 07:57:41 HD Request # 10 | Receiving Intraday data for EURAUD starting at 2017-11-27 07:54:16 | 2017-11-27 07:57:41 HD Request # 10 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:17 | 2017-11-27 07:57:41 Socket (15) | Initiating close of socket by core. | 2017-11-27 07:57:41 Socket (15) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:41 Historical data download thread signaled to stop. | 2017-11-27 07:57:41 HD Request # 10 | Received 536 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:39 (3.4 minutes) and wrote 524 records for EURAUD | 2017-11-27 07:57:41 HD Request # 10 | Intraday download COMPLETE for EURAUD. Completion time: 0s. Unique request ID: 9 | 2017-11-27 07:57:41 Removed historical data download ID 9 | 2017-11-27 07:57:41 Real-time Intraday chart data file updates started for EURAUD | 2017-11-27 07:57:41 Intraday chart data file opened for EURAUD | 2017-11-27 07:57:41 HD Request # 11 | Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: fxcm | 2017-11-27 07:57:41 HD Request # 11 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:41 HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:41 Socket (16) | Creating socket. | 2017-11-27 07:57:41 Socket (16) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:41 Socket (15) | Socket gracefully closed by remote side. | 2017-11-27 07:57:41 Socket (15) | Closed. | 2017-11-27 07:57:41 HD Request # 11 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:42 HD Request # 11 | Sending historical data logon request message. | 2017-11-27 07:57:42 HD Request # 11 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: EURCAD | 2017-11-27 07:57:42 Opened cached Intraday file: C:\SierraChart\Data\AUDCHF.scid | 2017-11-27 07:57:42 Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2017-11-27 07:57:42 Opened cached Intraday file: C:\SierraChart\Data\AUDNZD.scid | 2017-11-27 07:57:42 Opened cached Intraday file: C:\SierraChart\Data\AUDUSD.scid | 2017-11-27 07:57:42 Opened cached Intraday file: C:\SierraChart\Data\CADCHF.scid | 2017-11-27 07:57:42 Opened cached Intraday file: C:\SierraChart\Data\EURAUD.scid | 2017-11-27 07:57:42 HD Request # 11 | Decompressing data. | 2017-11-27 07:57:42 HD Request # 11 | Receiving Intraday data for EURCAD starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:42 HD Request # 11 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:42 Socket (16) | Initiating close of socket by core. | 2017-11-27 07:57:42 Socket (16) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:42 Historical data download thread signaled to stop. | 2017-11-27 07:57:42 HD Request # 11 | Received 337 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:39 (3.4 minutes) and wrote 336 records for EURCAD | 2017-11-27 07:57:42 HD Request # 11 | Intraday download COMPLETE for EURCAD. Completion time: 1s. Unique request ID: 10 | 2017-11-27 07:57:42 Removed historical data download ID 10 | 2017-11-27 07:57:42 Real-time Intraday chart data file updates started for EURCAD | 2017-11-27 07:57:42 Intraday chart data file opened for EURCAD | 2017-11-27 07:57:42 HD Request # 12 | Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: fxcm | 2017-11-27 07:57:42 HD Request # 12 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:42 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:42 Socket (17) | Creating socket. | 2017-11-27 07:57:42 Socket (17) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:42 Socket (16) | Socket gracefully closed by remote side. | 2017-11-27 07:57:42 Socket (16) | Closed. | 2017-11-27 07:57:42 HD Request # 12 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:43 HD Request # 12 | Sending historical data logon request message. | 2017-11-27 07:57:43 HD Request # 12 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: EURCHF | 2017-11-27 07:57:43 HD Request # 12 | Decompressing data. | 2017-11-27 07:57:43 HD Request # 12 | Receiving Intraday data for EURCHF starting at 2017-11-27 07:54:16 | 2017-11-27 07:57:43 HD Request # 12 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:43 Socket (17) | Initiating close of socket by core. | 2017-11-27 07:57:43 Socket (17) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:43 Historical data download thread signaled to stop. | 2017-11-27 07:57:43 HD Request # 12 | Received 232 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:38 (3.4 minutes) and wrote 230 records for EURCHF | 2017-11-27 07:57:43 HD Request # 12 | Intraday download COMPLETE for EURCHF. Completion time: 1s. Unique request ID: 11 | 2017-11-27 07:57:43 Removed historical data download ID 11 | 2017-11-27 07:57:43 Real-time Intraday chart data file updates started for EURCHF | 2017-11-27 07:57:43 Intraday chart data file opened for EURCHF | 2017-11-27 07:57:43 HD Request # 13 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2017-11-27 07:57:43 HD Request # 13 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:43 HD Request # 13 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:43 Socket (18) | Creating socket. | 2017-11-27 07:57:43 Socket (18) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:43 Socket (17) | Socket gracefully closed by remote side. | 2017-11-27 07:57:44 Socket (17) | Closed. | 2017-11-27 07:57:44 HD Request # 13 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:44 HD Request # 13 | Sending historical data logon request message. | 2017-11-27 07:57:44 HD Request # 13 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: EURGBP | 2017-11-27 07:57:44 HD Request # 13 | Decompressing data. | 2017-11-27 07:57:44 HD Request # 13 | Receiving Intraday data for EURGBP starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:44 HD Request # 13 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:44 Socket (18) | Initiating close of socket by core. | 2017-11-27 07:57:44 Historical data download thread signaled to stop. | 2017-11-27 07:57:44 Socket (18) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:44 HD Request # 13 | Received 465 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:40 (3.4 minutes) and wrote 464 records for EURGBP | 2017-11-27 07:57:44 Added 1 Time and Sales records to Intraday data file for EURGBP after download. | 2017-11-27 07:57:44 HD Request # 13 | Intraday download COMPLETE for EURGBP. Completion time: 0s. Unique request ID: 12 | 2017-11-27 07:57:44 Removed historical data download ID 12 | 2017-11-27 07:57:44 Real-time Intraday chart data file updates started for EURGBP | 2017-11-27 07:57:44 Intraday chart data file opened for EURGBP | 2017-11-27 07:57:44 HD Request # 14 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2017-11-27 07:57:44 HD Request # 14 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:44 HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:44 Socket (19) | Creating socket. | 2017-11-27 07:57:44 Socket (19) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:44 Socket (18) | Socket gracefully closed by remote side. | 2017-11-27 07:57:45 Socket (18) | Closed. | 2017-11-27 07:57:45 HD Request # 14 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:45 HD Request # 14 | Sending historical data logon request message. | 2017-11-27 07:57:45 HD Request # 14 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: EURJPY | 2017-11-27 07:57:45 HD Request # 14 | Decompressing data. | 2017-11-27 07:57:45 HD Request # 14 | Receiving Intraday data for EURJPY starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:45 HD Request # 14 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:45 Socket (19) | Initiating close of socket by core. | 2017-11-27 07:57:45 Socket (19) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:45 Historical data download thread signaled to stop. | 2017-11-27 07:57:45 HD Request # 14 | Received 692 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:42 (3.4 minutes) and wrote 690 records for EURJPY | 2017-11-27 07:57:45 Added 3 Time and Sales records to Intraday data file for EURJPY after download. | 2017-11-27 07:57:45 HD Request # 14 | Intraday download COMPLETE for EURJPY. Completion time: 1s. Unique request ID: 13 | 2017-11-27 07:57:45 Removed historical data download ID 13 | 2017-11-27 07:57:45 Real-time Intraday chart data file updates started for EURJPY | 2017-11-27 07:57:45 Intraday chart data file opened for EURJPY | 2017-11-27 07:57:45 HD Request # 15 | Downloading Intraday chart data for EURNZD to the file EURNZD.scid. Service: fxcm | 2017-11-27 07:57:45 HD Request # 15 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:57:45 HD Request # 15 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:45 Socket (20) | Creating socket. | 2017-11-27 07:57:45 Socket (20) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:45 Socket (19) | Socket gracefully closed by remote side. | 2017-11-27 07:57:46 Socket (19) | Closed. | 2017-11-27 07:57:46 HD Request # 15 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:46 HD Request # 15 | Sending historical data logon request message. | 2017-11-27 07:57:46 HD Request # 15 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: EURNZD | 2017-11-27 07:57:46 HD Request # 15 | Decompressing data. | 2017-11-27 07:57:46 HD Request # 15 | Receiving Intraday data for EURNZD starting at 2017-11-27 07:54:17 | 2017-11-27 07:57:46 HD Request # 15 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:46 Socket (20) | Initiating close of socket by core. | 2017-11-27 07:57:46 Socket (20) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:46 Historical data download thread signaled to stop. | 2017-11-27 07:57:46 HD Request # 15 | Received 384 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:39 (3.4 minutes) and wrote 382 records for EURNZD | 2017-11-27 07:57:46 HD Request # 15 | Intraday download COMPLETE for EURNZD. Completion time: 0s. Unique request ID: 14 | 2017-11-27 07:57:46 Removed historical data download ID 14 | 2017-11-27 07:57:46 Real-time Intraday chart data file updates started for EURNZD | 2017-11-27 07:57:46 Intraday chart data file opened for EURNZD | 2017-11-27 07:57:46 HD Request # 16 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2017-11-27 07:57:46 HD Request # 16 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:46 HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:46 Socket (21) | Creating socket. | 2017-11-27 07:57:46 Socket (21) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:46 Socket (20) | Socket gracefully closed by remote side. | 2017-11-27 07:57:47 Socket (20) | Closed. | 2017-11-27 07:57:47 HD Request # 16 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:47 HD Request # 16 | Sending historical data logon request message. | 2017-11-27 07:57:47 HD Request # 16 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: EURUSD | 2017-11-27 07:57:47 HD Request # 16 | Decompressing data. | 2017-11-27 07:57:47 HD Request # 16 | Receiving Intraday data for EURUSD starting at 2017-11-27 07:54:16 | 2017-11-27 07:57:47 HD Request # 16 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:47 Socket (21) | Initiating close of socket by core. | 2017-11-27 07:57:47 Socket (21) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:47 Historical data download thread signaled to stop. | 2017-11-27 07:57:47 HD Request # 16 | Received 346 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:38 (3.4 minutes) and wrote 343 records for EURUSD | 2017-11-27 07:57:47 HD Request # 16 | Intraday download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 15 | 2017-11-27 07:57:47 Removed historical data download ID 15 | 2017-11-27 07:57:47 Real-time Intraday chart data file updates started for EURUSD | 2017-11-27 07:57:47 Intraday chart data file opened for EURUSD | 2017-11-27 07:57:47 HD Request # 17 | Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: fxcm | 2017-11-27 07:57:47 HD Request # 17 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:57:47 HD Request # 17 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:47 Socket (22) | Creating socket. | 2017-11-27 07:57:47 Socket (22) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:47 Socket (21) | Socket gracefully closed by remote side. | 2017-11-27 07:57:48 Socket (21) | Closed. | 2017-11-27 07:57:48 HD Request # 17 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:48 HD Request # 17 | Sending historical data logon request message. | 2017-11-27 07:57:48 HD Request # 17 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: GBPAUD | 2017-11-27 07:57:49 HD Request # 17 | Decompressing data. | 2017-11-27 07:57:49 HD Request # 17 | Receiving Intraday data for GBPAUD starting at 2017-11-27 07:54:17 | 2017-11-27 07:57:49 HD Request # 17 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:49 Socket (22) | Initiating close of socket by core. | 2017-11-27 07:57:49 Socket (22) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:49 Historical data download thread signaled to stop. | 2017-11-27 07:57:49 HD Request # 17 | Received 754 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:48 (3.5 minutes) and wrote 753 records for GBPAUD | 2017-11-27 07:57:49 Added 2 Time and Sales records to Intraday data file for GBPAUD after download. | 2017-11-27 07:57:49 HD Request # 17 | Intraday download COMPLETE for GBPAUD. Completion time: 1s. Unique request ID: 16 | 2017-11-27 07:57:49 Removed historical data download ID 16 | 2017-11-27 07:57:49 Real-time Intraday chart data file updates started for GBPAUD | 2017-11-27 07:57:49 Intraday chart data file opened for GBPAUD | 2017-11-27 07:57:49 HD Request # 18 | Downloading Intraday chart data for GBPCAD to the file GBPCAD.scid. Service: fxcm | 2017-11-27 07:57:49 HD Request # 18 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:49 HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:49 Socket (23) | Creating socket. | 2017-11-27 07:57:49 Socket (23) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:49 Socket (22) | Socket gracefully closed by remote side. | 2017-11-27 07:57:49 Socket (22) | Closed. | 2017-11-27 07:57:49 HD Request # 18 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:49 HD Request # 18 | Sending historical data logon request message. | 2017-11-27 07:57:49 HD Request # 18 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: GBPCAD | 2017-11-27 07:57:49 HD Request # 18 | Decompressing data. | 2017-11-27 07:57:49 HD Request # 18 | Receiving Intraday data for GBPCAD starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:49 HD Request # 18 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:20 | 2017-11-27 07:57:49 Socket (23) | Initiating close of socket by core. | 2017-11-27 07:57:49 Socket (23) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:49 Historical data download thread signaled to stop. | 2017-11-27 07:57:49 HD Request # 18 | Received 330 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:47 (3.5 minutes) and wrote 329 records for GBPCAD | 2017-11-27 07:57:49 Added 3 Time and Sales records to Intraday data file for GBPCAD after download. | 2017-11-27 07:57:49 HD Request # 18 | Intraday download COMPLETE for GBPCAD. Completion time: 0s. Unique request ID: 17 | 2017-11-27 07:57:49 Removed historical data download ID 17 | 2017-11-27 07:57:49 Real-time Intraday chart data file updates started for GBPCAD | 2017-11-27 07:57:49 Intraday chart data file opened for GBPCAD | 2017-11-27 07:57:49 HD Request # 19 | Downloading Intraday chart data for GBPCHF to the file GBPCHF.scid. Service: fxcm | 2017-11-27 07:57:49 HD Request # 19 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:57:49 HD Request # 19 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:49 Socket (24) | Creating socket. | 2017-11-27 07:57:49 Socket (24) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:49 Socket (23) | Socket gracefully closed by remote side. | 2017-11-27 07:57:50 Socket (23) | Closed. | 2017-11-27 07:57:50 HD Request # 19 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:50 HD Request # 19 | Sending historical data logon request message. | 2017-11-27 07:57:50 HD Request # 19 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: GBPCHF | 2017-11-27 07:57:50 HD Request # 19 | Decompressing data. | 2017-11-27 07:57:50 HD Request # 19 | Receiving Intraday data for GBPCHF starting at 2017-11-27 07:54:17 | 2017-11-27 07:57:50 HD Request # 19 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:50 Socket (24) | Initiating close of socket by core. | 2017-11-27 07:57:50 Socket (24) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:50 Historical data download thread signaled to stop. | 2017-11-27 07:57:50 HD Request # 19 | Received 398 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:49 (3.5 minutes) and wrote 397 records for GBPCHF | 2017-11-27 07:57:50 HD Request # 19 | Intraday download COMPLETE for GBPCHF. Completion time: 1s. Unique request ID: 18 | 2017-11-27 07:57:50 Removed historical data download ID 18 | 2017-11-27 07:57:50 Real-time Intraday chart data file updates started for GBPCHF | 2017-11-27 07:57:50 Intraday chart data file opened for GBPCHF | 2017-11-27 07:57:50 HD Request # 20 | Downloading Intraday chart data for GBPJPY to the file GBPJPY.scid. Service: fxcm | 2017-11-27 07:57:50 HD Request # 20 | Download start date-time: 2017-11-27 07:54:14.000 | 2017-11-27 07:57:50 HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:50 Socket (25) | Creating socket. | 2017-11-27 07:57:50 Socket (25) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:50 Socket (24) | Socket gracefully closed by remote side. | 2017-11-27 07:57:51 Socket (24) | Closed. | 2017-11-27 07:57:51 HD Request # 20 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:52 HD Request # 20 | Sending historical data logon request message. | 2017-11-27 07:57:52 HD Request # 20 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:14. Record interval: 0. Symbol: GBPJPY | 2017-11-27 07:57:52 HD Request # 20 | Decompressing data. | 2017-11-27 07:57:52 HD Request # 20 | Receiving Intraday data for GBPJPY starting at 2017-11-27 07:54:14 | 2017-11-27 07:57:52 HD Request # 20 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:19 | 2017-11-27 07:57:52 Socket (25) | Initiating close of socket by core. | 2017-11-27 07:57:52 Socket (25) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:52 Historical data download thread signaled to stop. | 2017-11-27 07:57:52 HD Request # 20 | Received 555 records from 2017-11-27 07:54:14 to 2017-11-27 07:57:49 (3.6 minutes) and wrote 553 records for GBPJPY | 2017-11-27 07:57:52 Added 4 Time and Sales records to Intraday data file for GBPJPY after download. | 2017-11-27 07:57:52 HD Request # 20 | Intraday download COMPLETE for GBPJPY. Completion time: 2s. Unique request ID: 19 | 2017-11-27 07:57:52 Removed historical data download ID 19 | 2017-11-27 07:57:52 Real-time Intraday chart data file updates started for GBPJPY | 2017-11-27 07:57:52 Intraday chart data file opened for GBPJPY | 2017-11-27 07:57:52 HD Request # 21 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2017-11-27 07:57:52 HD Request # 21 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:52 HD Request # 21 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:52 Socket (26) | Creating socket. | 2017-11-27 07:57:52 Socket (26) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:52 Socket (25) | Socket gracefully closed by remote side. | 2017-11-27 07:57:52 Socket (25) | Closed. | 2017-11-27 07:57:52 HD Request # 21 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:53 HD Request # 21 | Sending historical data logon request message. | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\CADJPY.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\CHFJPY.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\EURCAD.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\EURCHF.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\EURGBP.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\EURJPY.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\EURNZD.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\GBPAUD.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\GBPCAD.scid | 2017-11-27 07:57:53 Opened cached Intraday file: C:\SierraChart\Data\GBPCHF.scid | 2017-11-27 07:57:53 HD Request # 21 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: GBPNZD | 2017-11-27 07:57:53 HD Request # 21 | Decompressing data. | 2017-11-27 07:57:53 HD Request # 21 | Receiving Intraday data for GBPNZD starting at 2017-11-27 07:54:16 | 2017-11-27 07:57:53 HD Request # 21 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:19 | 2017-11-27 07:57:53 Socket (26) | Initiating close of socket by core. | 2017-11-27 07:57:53 Socket (26) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:53 Historical data download thread signaled to stop. | 2017-11-27 07:57:53 HD Request # 21 | Received 410 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:50 (3.6 minutes) and wrote 407 records for GBPNZD | 2017-11-27 07:57:53 HD Request # 21 | Intraday download COMPLETE for GBPNZD. Completion time: 1s. Unique request ID: 20 | 2017-11-27 07:57:53 Removed historical data download ID 20 | 2017-11-27 07:57:53 Real-time Intraday chart data file updates started for GBPNZD | 2017-11-27 07:57:53 Intraday chart data file opened for GBPNZD | 2017-11-27 07:57:53 HD Request # 22 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2017-11-27 07:57:53 HD Request # 22 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:53 HD Request # 22 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:53 Socket (27) | Creating socket. | 2017-11-27 07:57:53 Socket (27) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:53 Socket (26) | Socket gracefully closed by remote side. | 2017-11-27 07:57:53 Socket (26) | Closed. | 2017-11-27 07:57:53 HD Request # 22 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:54 HD Request # 22 | Sending historical data logon request message. | 2017-11-27 07:57:54 HD Request # 22 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: GBPUSD | 2017-11-27 07:57:54 HD Request # 22 | Decompressing data. | 2017-11-27 07:57:54 HD Request # 22 | Receiving Intraday data for GBPUSD starting at 2017-11-27 07:54:16 | 2017-11-27 07:57:54 HD Request # 22 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:54 Socket (27) | Initiating close of socket by core. | 2017-11-27 07:57:54 Socket (27) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:54 Historical data download thread signaled to stop. | 2017-11-27 07:57:54 HD Request # 22 | Received 645 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:51 (3.6 minutes) and wrote 644 records for GBPUSD | 2017-11-27 07:57:54 Added 8 Time and Sales records to Intraday data file for GBPUSD after download. | 2017-11-27 07:57:54 HD Request # 22 | Intraday download COMPLETE for GBPUSD. Completion time: 1s. Unique request ID: 21 | 2017-11-27 07:57:54 Removed historical data download ID 21 | 2017-11-27 07:57:54 Real-time Intraday chart data file updates started for GBPUSD | 2017-11-27 07:57:54 Intraday chart data file opened for GBPUSD | 2017-11-27 07:57:54 HD Request # 23 | Downloading Intraday chart data for NZDCAD to the file NZDCAD.scid. Service: fxcm | 2017-11-27 07:57:54 HD Request # 23 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:54 HD Request # 23 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:54 Socket (28) | Creating socket. | 2017-11-27 07:57:54 Socket (28) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:54 Socket (27) | Socket gracefully closed by remote side. | 2017-11-27 07:57:54 Socket (27) | Closed. | 2017-11-27 07:57:54 HD Request # 23 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:55 HD Request # 23 | Sending historical data logon request message. | 2017-11-27 07:57:55 HD Request # 23 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: NZDCAD | 2017-11-27 07:57:55 HD Request # 23 | Decompressing data. | 2017-11-27 07:57:55 HD Request # 23 | Receiving Intraday data for NZDCAD starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:55 HD Request # 23 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:19 | 2017-11-27 07:57:55 Socket (28) | Initiating close of socket by core. | 2017-11-27 07:57:55 Socket (28) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:55 Historical data download thread signaled to stop. | 2017-11-27 07:57:55 HD Request # 23 | Received 346 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:49 (3.5 minutes) and wrote 345 records for NZDCAD | 2017-11-27 07:57:55 HD Request # 23 | Intraday download COMPLETE for NZDCAD. Completion time: 0s. Unique request ID: 22 | 2017-11-27 07:57:55 Removed historical data download ID 22 | 2017-11-27 07:57:55 Real-time Intraday chart data file updates started for NZDCAD | 2017-11-27 07:57:55 Intraday chart data file opened for NZDCAD | 2017-11-27 07:57:55 HD Request # 24 | Downloading Intraday chart data for NZDCHF to the file NZDCHF.scid. Service: fxcm | 2017-11-27 07:57:55 HD Request # 24 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:57:55 HD Request # 24 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:55 Socket (29) | Creating socket. | 2017-11-27 07:57:55 Socket (29) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:55 Socket (28) | Socket gracefully closed by remote side. | 2017-11-27 07:57:55 Socket (28) | Closed. | 2017-11-27 07:57:55 HD Request # 24 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:56 HD Request # 24 | Sending historical data logon request message. | 2017-11-27 07:57:56 HD Request # 24 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: NZDCHF | 2017-11-27 07:57:56 HD Request # 24 | Decompressing data. | 2017-11-27 07:57:56 HD Request # 24 | Receiving Intraday data for NZDCHF starting at 2017-11-27 07:54:17 | 2017-11-27 07:57:56 HD Request # 24 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:19 | 2017-11-27 07:57:56 Socket (29) | Initiating close of socket by core. | 2017-11-27 07:57:56 Socket (29) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:56 Historical data download thread signaled to stop. | 2017-11-27 07:57:56 HD Request # 24 | Received 303 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:55 (3.6 minutes) and wrote 301 records for NZDCHF | 2017-11-27 07:57:56 HD Request # 24 | Intraday download COMPLETE for NZDCHF. Completion time: 1s. Unique request ID: 23 | 2017-11-27 07:57:56 Removed historical data download ID 23 | 2017-11-27 07:57:56 Real-time Intraday chart data file updates started for NZDCHF | 2017-11-27 07:57:56 Intraday chart data file opened for NZDCHF | 2017-11-27 07:57:56 HD Request # 25 | Downloading Intraday chart data for NZDJPY to the file NZDJPY.scid. Service: fxcm | 2017-11-27 07:57:56 HD Request # 25 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:56 HD Request # 25 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:56 Socket (30) | Creating socket. | 2017-11-27 07:57:56 Socket (30) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:56 Socket (29) | Socket gracefully closed by remote side. | 2017-11-27 07:57:56 Socket (29) | Closed. | 2017-11-27 07:57:56 HD Request # 25 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:57 HD Request # 25 | Sending historical data logon request message. | 2017-11-27 07:57:57 HD Request # 25 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: NZDJPY | 2017-11-27 07:57:57 HD Request # 25 | Decompressing data. | 2017-11-27 07:57:57 HD Request # 25 | Receiving Intraday data for NZDJPY starting at 2017-11-27 07:54:16 | 2017-11-27 07:57:57 HD Request # 25 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:19 | 2017-11-27 07:57:57 Socket (30) | Initiating close of socket by core. | 2017-11-27 07:57:57 Socket (30) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:57 Historical data download thread signaled to stop. | 2017-11-27 07:57:57 HD Request # 25 | Received 330 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:55 (3.7 minutes) and wrote 326 records for NZDJPY | 2017-11-27 07:57:57 Added 1 Time and Sales records to Intraday data file for NZDJPY after download. | 2017-11-27 07:57:57 HD Request # 25 | Intraday download COMPLETE for NZDJPY. Completion time: 0s. Unique request ID: 24 | 2017-11-27 07:57:57 Removed historical data download ID 24 | 2017-11-27 07:57:57 Real-time Intraday chart data file updates started for NZDJPY | 2017-11-27 07:57:57 Intraday chart data file opened for NZDJPY | 2017-11-27 07:57:57 HD Request # 26 | Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: fxcm | 2017-11-27 07:57:57 HD Request # 26 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:57 HD Request # 26 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:57 Socket (31) | Creating socket. | 2017-11-27 07:57:57 Socket (31) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:57 Socket (30) | Socket gracefully closed by remote side. | 2017-11-27 07:57:57 Socket (30) | Closed. | 2017-11-27 07:57:57 HD Request # 26 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:58 HD Request # 26 | Sending historical data logon request message. | 2017-11-27 07:57:58 HD Request # 26 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: NZDUSD | 2017-11-27 07:57:58 HD Request # 26 | Decompressing data. | 2017-11-27 07:57:58 HD Request # 26 | Receiving Intraday data for NZDUSD starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:58 HD Request # 26 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:19 | 2017-11-27 07:57:58 Socket (31) | Initiating close of socket by core. | 2017-11-27 07:57:58 Socket (31) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:58 Historical data download thread signaled to stop. | 2017-11-27 07:57:58 HD Request # 26 | Received 882 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:55 (3.6 minutes) and wrote 880 records for NZDUSD | 2017-11-27 07:57:58 HD Request # 26 | Intraday download COMPLETE for NZDUSD. Completion time: 1s. Unique request ID: 25 | 2017-11-27 07:57:58 Removed historical data download ID 25 | 2017-11-27 07:57:58 Real-time Intraday chart data file updates started for NZDUSD | 2017-11-27 07:57:58 Intraday chart data file opened for NZDUSD | 2017-11-27 07:57:58 HD Request # 27 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2017-11-27 07:57:58 HD Request # 27 | Download start date-time: 2017-11-27 07:54:18.000 | 2017-11-27 07:57:58 HD Request # 27 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:57:58 Socket (32) | Creating socket. | 2017-11-27 07:57:58 Socket (32) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:57:58 Socket (31) | Socket gracefully closed by remote side. | 2017-11-27 07:57:59 Socket (31) | Closed. | 2017-11-27 07:57:59 HD Request # 27 | Setting DTC encoding to Binary VLS | 2017-11-27 07:57:59 HD Request # 27 | Sending historical data logon request message. | 2017-11-27 07:57:59 HD Request # 27 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:18. Record interval: 0. Symbol: USDCAD | 2017-11-27 07:57:59 HD Request # 27 | Decompressing data. | 2017-11-27 07:57:59 HD Request # 27 | Receiving Intraday data for USDCAD starting at 2017-11-27 07:54:18 | 2017-11-27 07:57:59 HD Request # 27 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:57:59 Socket (32) | Initiating close of socket by core. | 2017-11-27 07:57:59 Socket (32) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:57:59 Historical data download thread signaled to stop. | 2017-11-27 07:57:59 HD Request # 27 | Received 360 records from 2017-11-27 07:54:18 to 2017-11-27 07:57:55 (3.6 minutes) and wrote 358 records for USDCAD | 2017-11-27 07:57:59 Added 1 Time and Sales records to Intraday data file for USDCAD after download. | 2017-11-27 07:57:59 HD Request # 27 | Intraday download COMPLETE for USDCAD. Completion time: 1s. Unique request ID: 26 | 2017-11-27 07:57:59 Removed historical data download ID 26 | 2017-11-27 07:57:59 Real-time Intraday chart data file updates started for USDCAD | 2017-11-27 07:57:59 Intraday chart data file opened for USDCAD | 2017-11-27 07:57:59 HD Request # 28 | Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: fxcm | 2017-11-27 07:57:59 HD Request # 28 | Download start date-time: 2017-11-27 07:54:16.000 | 2017-11-27 07:57:59 HD Request # 28 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 07:57:59 Socket (33) | Creating socket. | 2017-11-27 07:57:59 Socket (33) | Connecting to IP: 192.81.56.146. | 2017-11-27 07:57:59 Socket (32) | Socket gracefully closed by remote side. | 2017-11-27 07:58:00 Socket (32) | Closed. | 2017-11-27 07:58:00 HD Request # 28 | Setting DTC encoding to Binary VLS | 2017-11-27 07:58:00 HD Request # 28 | Sending historical data logon request message. | 2017-11-27 07:58:00 HD Request # 28 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:16. Record interval: 0. Symbol: USDCHF | 2017-11-27 07:58:00 HD Request # 28 | Decompressing data. | 2017-11-27 07:58:00 HD Request # 28 | Receiving Intraday data for USDCHF starting at 2017-11-27 07:54:16 | 2017-11-27 07:58:00 HD Request # 28 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:58:00 Socket (33) | Initiating close of socket by core. | 2017-11-27 07:58:00 Socket (33) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:58:00 Historical data download thread signaled to stop. | 2017-11-27 07:58:00 HD Request # 28 | Received 317 records from 2017-11-27 07:54:16 to 2017-11-27 07:57:59 (3.7 minutes) and wrote 314 records for USDCHF | 2017-11-27 07:58:00 HD Request # 28 | Intraday download COMPLETE for USDCHF. Completion time: 0s. Unique request ID: 27 | 2017-11-27 07:58:00 Removed historical data download ID 27 | 2017-11-27 07:58:00 Real-time Intraday chart data file updates started for USDCHF | 2017-11-27 07:58:00 Intraday chart data file opened for USDCHF | 2017-11-27 07:58:00 HD Request # 29 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2017-11-27 07:58:00 HD Request # 29 | Download start date-time: 2017-11-27 07:54:17.000 | 2017-11-27 07:58:00 HD Request # 29 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 07:58:00 Socket (34) | Creating socket. | 2017-11-27 07:58:00 Socket (34) | Connecting to IP: 65.182.172.42. | 2017-11-27 07:58:00 Socket (33) | Socket gracefully closed by remote side. | 2017-11-27 07:58:01 Socket (33) | Closed. | 2017-11-27 07:58:01 HD Request # 29 | Setting DTC encoding to Binary VLS | 2017-11-27 07:58:01 HD Request # 29 | Sending historical data logon request message. | 2017-11-27 07:58:01 HD Request # 29 | Requesting Intraday data. Start date-time: 2017-11-27 07:54:17. Record interval: 0. Symbol: USDJPY | 2017-11-27 07:58:01 HD Request # 29 | Decompressing data. | 2017-11-27 07:58:01 HD Request # 29 | Receiving Intraday data for USDJPY starting at 2017-11-27 07:54:17 | 2017-11-27 07:58:01 HD Request # 29 | Timestamp of first Intraday data file record written: 2017-11-27 07:54:18 | 2017-11-27 07:58:01 Socket (34) | Initiating close of socket by core. | 2017-11-27 07:58:01 Socket (34) | Shutdown started. Waiting for graceful close. | 2017-11-27 07:58:01 Historical data download thread signaled to stop. | 2017-11-27 07:58:01 HD Request # 29 | Received 480 records from 2017-11-27 07:54:17 to 2017-11-27 07:57:59 (3.7 minutes) and wrote 477 records for USDJPY | 2017-11-27 07:58:01 HD Request # 29 | Intraday download COMPLETE for USDJPY. Completion time: 1s. Unique request ID: 28 | 2017-11-27 07:58:01 Removed historical data download ID 28 | 2017-11-27 07:58:01 Real-time Intraday chart data file updates started for USDJPY | 2017-11-27 07:58:01 Intraday chart data file opened for USDJPY | 2017-11-27 07:58:01 Socket (34) | Socket gracefully closed by remote side. | 2017-11-27 07:58:02 Socket (34) | Closed. | 2017-11-27 07:58:02 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\GBPJPY.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\GBPNZD.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\NZDCAD.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\NZDCHF.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\NZDJPY.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\NZDUSD.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\USDCAD.scid | 2017-11-27 07:58:03 Opened cached Intraday file: C:\SierraChart\Data\USDCHF.scid | 2017-11-27 07:58:13 Opened cached Intraday file: C:\SierraChart\Data\USDJPY.scid | 2017-11-27 07:58:13 AUDJPY [M] 5 Min #3 | Reloading chart. | 2017-11-27 07:58:45 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-11-27 07:58:46 AUDJPY [M] 5 Min #3 | Reloading chart. | 2017-11-27 08:03:01 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-11-27 08:03:02 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-11-27 08:03:23 HD Request # 30 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-11-27 08:03:23 HD Request # 30 | Download start date-time: 2017-11-27 08:03:23.000 | 2017-11-27 08:03:23 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 08:03:23 Socket (37) | Creating socket. | 2017-11-27 08:03:23 Socket (37) | Connecting to IP: 192.81.56.146. | 2017-11-27 08:03:23 HD Request # 30 | Setting DTC encoding to Binary VLS | 2017-11-27 08:03:24 HD Request # 30 | Sending historical data logon request message. | 2017-11-27 08:03:24 HD Request # 30 | Requesting Intraday data. Start date-time: 2017-11-27 08:03:23. Record interval: 0. Symbol: AUDJPY | 2017-11-27 08:03:24 HD Request # 30 | Decompressing data. | 2017-11-27 08:03:24 HD Request # 30 | Receiving Intraday data for AUDJPY starting at 2017-11-27 08:03:23 | 2017-11-27 08:03:24 Socket (37) | Initiating close of socket by core. | 2017-11-27 08:03:24 Socket (37) | Shutdown started. Waiting for graceful close. | 2017-11-27 08:03:24 Historical data download thread signaled to stop. | 2017-11-27 08:03:24 HD Request # 30 | Received 2 records from 2017-11-27 08:03:23 to 2017-11-27 08:03:23 (0.0 seconds) and wrote 0 records for AUDJPY | 2017-11-27 08:03:24 HD Request # 30 | Timestamp of first Intraday data file record written: 2017-11-27 08:03:23 | 2017-11-27 08:03:24 Added 4 Time and Sales records to Intraday data file for AUDJPY after download. | 2017-11-27 08:03:24 HD Request # 30 | Intraday download COMPLETE for AUDJPY. Completion time: 1s. Unique request ID: 29 | 2017-11-27 08:03:24 Removed historical data download ID 29 | 2017-11-27 08:03:24 Real-time Intraday chart data file updates started for AUDJPY | 2017-11-27 08:03:24 Intraday chart data file opened for AUDJPY | 2017-11-27 08:03:24 Socket (37) | Socket gracefully closed by remote side. | 2017-11-27 08:03:25 Socket (37) | Closed. | 2017-11-27 08:03:25 Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2017-11-27 08:03:26 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-11-27 08:03:34 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-11-27 08:03:41 HD Request # 31 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-11-27 08:03:41 HD Request # 31 | Download start date-time: 2017-11-27 07:59:59.000 | 2017-11-27 08:03:41 HD Request # 31 | Disabling Intraday chart updating for symbol during historical data download. | 2017-11-27 08:03:41 HD Request # 31 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 08:03:41 Socket (38) | Creating socket. | 2017-11-27 08:03:41 Socket (38) | Connecting to IP: 65.182.172.42. | 2017-11-27 08:03:41 HD Request # 31 | Setting DTC encoding to Binary VLS | 2017-11-27 08:03:41 HD Request # 31 | Sending historical data logon request message. | 2017-11-27 08:03:41 HD Request # 31 | Requesting Intraday data. Start date-time: 2017-11-27 07:59:59. Record interval: 0. Symbol: AUDJPY | 2017-11-27 08:03:41 HD Request # 31 | Decompressing data. | 2017-11-27 08:03:42 HD Request # 31 | Receiving Intraday data for AUDJPY starting at 2017-11-27 07:59:59 | 2017-11-27 08:03:42 HD Request # 31 | Truncating file to starting date-time of 2017-11-27 07:59:59 | 2017-11-27 08:03:42 HD Request # 31 | Timestamp of first Intraday data file record written: 2017-11-27 07:59:59 | 2017-11-27 08:03:42 Socket (38) | Initiating close of socket by core. | 2017-11-27 08:03:42 Socket (38) | Shutdown started. Waiting for graceful close. | 2017-11-27 08:03:42 Historical data download thread signaled to stop. | 2017-11-27 08:03:42 HD Request # 31 | Received 1393 records from 2017-11-27 07:59:59 to 2017-11-27 08:03:38 (3.6 minutes) and wrote 1393 records for AUDJPY | 2017-11-27 08:03:42 Added 2 Time and Sales records to Intraday data file for AUDJPY after download. | 2017-11-27 08:03:42 HD Request # 31 | Intraday download COMPLETE for AUDJPY. Completion time: 2s. Unique request ID: 30 | 2017-11-27 08:03:42 Removed historical data download ID 30 | 2017-11-27 08:03:42 Real-time Intraday chart data file updates started for AUDJPY | 2017-11-27 08:03:42 Intraday chart data file opened for AUDJPY | 2017-11-27 08:03:42 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2017-11-27 08:03:42 HD Request # 31 | Reloading Intraday charts for AUDJPY | 2017-11-27 08:03:42 Reloading all charts with filename: AUDJPY.scid | 2017-11-27 08:03:42 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-11-27 08:03:42 Socket (38) | Socket gracefully closed by remote side. | 2017-11-27 08:03:42 Socket (38) | Closed. | 2017-11-27 08:03:42 Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2017-11-27 08:03:46 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2017-11-27 08:03:53 Reloading all charts with filename: AUDJPY.scid | 2017-11-27 08:03:53 HD Request # 32 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-11-27 08:03:53 HD Request # 32 | Download start date-time: 2016-11-27 08:03:53.000 | 2017-11-27 08:03:53 HD Request # 32 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 08:03:53 Socket (39) | Creating socket. | 2017-11-27 08:03:53 Socket (39) | Connecting to IP: 192.81.56.146. | 2017-11-27 08:03:53 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-11-27 08:03:53 AUDJPY [M] 60 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\AUDJPY.scid | 2017-11-27 08:03:53 HD Request # 32 | Setting DTC encoding to Binary VLS | 2017-11-27 08:03:54 HD Request # 32 | Sending historical data logon request message. | 2017-11-27 08:03:54 HD Request # 32 | Requesting Intraday data. Start date-time: 2016-11-27 08:03:53. Record interval: 0. Symbol: AUDJPY | 2017-11-27 08:03:54 HD Request # 32 | Decompressing data. | 2017-11-27 08:03:54 HD Request # 32 | Receiving Intraday data for AUDJPY starting at 2016-11-27 22:00:01 | 2017-11-27 08:03:54 HD Request # 32 | Timestamp of first Intraday data file record written: 2016-11-27 22:00:01 | 2017-11-27 08:03:54 Socket (39) | Received socket Close event. | 2017-11-27 08:07:57 Socket (39) | Socket gracefully closed by remote side. | 2017-11-27 08:07:57 Socket (39) | 65 bytes remaining in receive buffer when socket closed. | 2017-11-27 08:07:57 Socket (39) | Initiating close of socket by core. | 2017-11-27 08:07:57 Socket (39) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-27 08:07:57 Socket (39) | Closed. | 2017-11-27 08:07:57 HD Request # 32 | Error downloading historical Intraday data for AUDJPY. The network socket has been closed. Retrying download. | 2017-11-27 08:07:57 Historical data download thread signaled to stop. | 2017-11-27 08:07:57 HD Request # 32 | Received 14518191 records from 2016-11-27 22:00:01 to 2017-01-27 13:15:09 (60.6 days) and wrote 14518191 records for AUDJPY | 2017-11-27 08:07:57 HD Request # 33 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-11-27 08:07:57 HD Request # 33 | Download start date-time: 2017-01-27 13:15:09.000 | 2017-11-27 08:07:57 HD Request # 33 | Using server: ds3.sierracharts.com port 10150 | 2017-11-27 08:07:57 Socket (41) | Creating socket. | 2017-11-27 08:07:57 Socket (41) | Connecting to IP: 65.182.172.42. | 2017-11-27 08:07:57 HD Request # 33 | Setting DTC encoding to Binary VLS | 2017-11-27 08:07:58 HD Request # 33 | Sending historical data logon request message. | 2017-11-27 08:07:58 HD Request # 33 | Requesting Intraday data. Start date-time: 2017-01-27 13:15:09. Record interval: 0. Symbol: AUDJPY | 2017-11-27 08:07:58 HD Request # 33 | Decompressing data. | 2017-11-27 08:07:58 HD Request # 33 | Receiving Intraday data for AUDJPY starting at 2017-01-27 13:15:09 | 2017-11-27 08:07:58 HD Request # 33 | Timestamp of first Intraday data file record written: 2017-01-27 13:15:09 | 2017-11-27 08:07:58 Socket (41) | Received socket Close event. | 2017-11-27 08:12:00 Socket (41) | Socket gracefully closed by remote side. | 2017-11-27 08:12:00 Socket (41) | Initiating close of socket by core. | 2017-11-27 08:12:00 HD Request # 33 | Error downloading historical Intraday data for AUDJPY. The network socket has been closed. Retrying download. | 2017-11-27 08:12:00 Socket (41) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-27 08:12:00 Socket (41) | Closed. | 2017-11-27 08:12:00 Historical data download thread signaled to stop. | 2017-11-27 08:12:00 HD Request # 33 | Received 12843422 records from 2017-01-27 13:15:09 to 2017-03-31 16:52:21 (63.2 days) and wrote 12843421 records for AUDJPY | 2017-11-27 08:12:00 HD Request # 34 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-11-27 08:12:00 HD Request # 34 | Download start date-time: 2017-03-31 16:52:21.000 | 2017-11-27 08:12:00 HD Request # 34 | Using server: ds4.sierracharts.com port 10149 | 2017-11-27 08:12:00 Socket (44) | Creating socket. | 2017-11-27 08:12:00 Socket (44) | Connecting to IP: 192.81.56.146. | 2017-11-27 08:12:00 HD Request # 34 | Setting DTC encoding to Binary VLS | 2017-11-27 08:12:01 HD Request # 34 | Sending historical data logon request message. | 2017-11-27 08:12:01 HD Request # 34 | Requesting Intraday data. Start date-time: 2017-03-31 16:52:21. Record interval: 0. Symbol: AUDJPY | 2017-11-27 08:12:01 HD Request # 34 | Decompressing data. | 2017-11-27 08:12:01 HD Request # 34 | Receiving Intraday data for AUDJPY starting at 2017-03-31 16:52:21 | 2017-11-27 08:12:01 HD Request # 34 | Timestamp of first Intraday data file record written: 2017-03-31 16:52:21 | 2017-11-27 08:12:01 Socket (44) | Received socket Close event. | 2017-11-27 08:16:02 Socket (44) | Socket gracefully closed by remote side. | 2017-11-27 08:16:02 Socket (44) | 445 bytes remaining in receive buffer when socket closed. | 2017-11-27 08:16:02 Socket (44) | Initiating close of socket by core. | 2017-11-27 08:16:02 Socket (44) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-27 08:16:02 Socket (44) | Closed. | 2017-11-27 08:16:02 HD Request # 34 | Error downloading historical Intraday data for AUDJPY. The network socket has been closed. Retrying download. | 2017-11-27 08:16:02 Historical data download thread signaled to stop. | 2017-11-27 08:16:02 HD Request # 34 | Received 15335240 records from 2017-03-31 16:52:21 to 2017-07-07 01:07:17 (97.3 days) and wrote 15335235 records for AUDJPY | 2017-11-27 08:16:02 Added 4688 Time and Sales records to Intraday data file for AUDJPY after download. | 2017-11-27 08:16:02 HD Request # 34 | Intraday download COMPLETE for AUDJPY. Completion time: 4m 2s. Unique request ID: 31 | 2017-11-27 08:16:02 Removed historical data download ID 31 | 2017-11-27 08:16:02 Real-time Intraday chart data file updates started for AUDJPY | 2017-11-27 08:16:02 Intraday chart data file opened for AUDJPY | 2017-11-27 08:16:02 Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2017-11-27 08:16:06 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-11-27 08:17:52 AUDJPY [M] 5 Min #3 | Reloading chart. | 2017-11-27 08:18:01 AUDJPY [M] 5 Min #3 | Reloading chart. | 2017-11-27 09:22:50 AUDJPY [M] 5 Min #3 | Reloading chart. | 2017-11-27 09:27:12 AUDJPY [M] 60 Min #3 | Reloading chart. | 2017-11-27 09:27:14 Uploaded an image to the server. Request ID: 1 | 2017-11-27 09:37:41 HTTPS connection to www.sierrachart.com:443 (74) | Creating socket. Using TLS 1.2. | 2017-11-27 09:37:41 HTTPS connection to www.sierrachart.com:443 (74) | Connecting to IP: 204.15.192.108. | 2017-11-27 09:37:41 HTTPS connection to www.sierrachart.com:443 (74) | Socket gracefully closed by remote side. | 2017-11-27 09:37:50 HTTPS connection to www.sierrachart.com:443 (74) | Received socket Close event. | 2017-11-27 09:37:50 HTTPS connection to www.sierrachart.com:443 (74) | Initiating close of socket by core. | 2017-11-27 09:37:50 HTTPS connection to www.sierrachart.com:443 (74) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-27 09:37:50 HTTPS connection to www.sierrachart.com:443 (74) | Closed. | 2017-11-27 09:37:50 |
| [2017-11-27 18:19:44] |
You are repeatedly getting this error: HD Request # 33 | Error downloading historical Intraday data for AUDJPY. The network socket has been closed. Retrying download. | 2017-11-27 08:12:00 There is some kind of Internet connectivity issue you are having. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-11-27 18:33:13] |
Actually right now disregard the answer at post #3 above. This might be an issue on our server side. We are looking into it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-27 18:33:28
| [2017-11-27 20:51:21] |
| User106180 - Posts: 88 |
I also saw this error message but don't think that it was an issue with my internet connectivity as everything else on my computer is getting data, and I'd tried redownloading several times. Out of the 28 major currency pair combinations (including AUD, CAD, CHF, EUD, GBP, JPY, NZD, USD) I have only tried redownloading several times AUDJPY. It appears as though only the following currency pairs have all data: - AUDCAD - AUDCHF - CADCHF - NZDCAD - NZDCHF All other currency pairs have visible data gaps to differing extents. Thank you for your help once again. |
| [2017-11-27 21:17:11] |
In part we do see this as an issue on the server and we are resolving that. It will be about an hour.
| [2017-11-27 21:45:42] |
The problem is confirmed to be resolved. Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
