Date/Time: Sun, 05 May 2024 13:40:07 +0000
How to code in Sierra Charts?
View Count: 1685
[2017-11-27 01:49:00] |
User243490 - Posts: 1 |
If possible what coding languages are supported?
[2017-11-27 02:03:04] |
It depends what you want to do. The more advanced programming interface called ACSIL is documented here: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
