Date/Time: Thu, 03 Jul 2025 04:28:20 +0000
[User Discussion] - ACSIL - A function that returns the Bar Period Type and Setting
View Count: 1784
[2017-11-26 16:49:51]
Zosimus - Posts: 345
Anyone knows an ACSIL function that returns the Bar Period Type and Setting?
For an example "3.00 Range" or "5 Min".
The sc.GetChartName(ChartNum)function does return a string that includes this info but during replays it returns a different string ("Replay SpeedX")and this is problematic for my code.
[2017-11-27 12:17:08]
DabbaDo - Posts: 148
Not a very good solution, but I parse GetStudyName(0). See SCExtensions.h/SCExtension.cpp at my public Github at https://github.com/dalebrubaker/BruSierraChart
void GetContinuousContractAndBarsPeriodTypeCodes(SCStudyInterfaceRef sc, SCString& ccCode, SCString& barsPeriodType)
    SCString thisName = sc.GetStudyName(0); // like ESM7 [CB] Flex Renko 32-31-1 #5 --but Continuous None gives no []
    std::vector<char*> tokens;
    thisName.Tokenize(" ", tokens);
   const SCString token0 = tokens[0];
    if (tokens.size() < 3
      || token0 != sc.Symbol)
      ccCode = barsPeriodType = "INVALID";
      return;
   const auto token1 = tokens[1];
    int barsPeriodStartIndex;
    if (token1[0] == '[')
      ccCode = token1;
      barsPeriodStartIndex = 2;
    else
      ccCode = "[C0]";
      barsPeriodStartIndex = 1;
    for (size_t i = barsPeriodStartIndex; i < tokens.size() - 2; i++)
     const auto token = tokens[i];
      const int len = strlen(token);
      if (len > 0)
        barsPeriodType += tokens[i];
[2017-11-27 12:52:25]
Many thanks DabbaDo this will definitely help. I've just checked and saw that unlike the sc.GetChartName() in the case of sc.GetStudyName(0) the bar period portion of the string doesn't change on replays.
[2017-11-29 04:14:20]
StevieD - Posts: 39
Unless I misunderstand the question, the SC "Are" functions are what you are looking for...
sc.AreTimeSpecificBars()
sc.AreRangeBars()
sc.AreVolumeBars()
and others.
Combine with sc variable calls like...
sc.SecondsPerBar
sc.VolumePerBar
sc.RangeBarType
HTH
[2017-11-30 20:57:47]
thanks StevieD, I'm not sure that the "Are" functions include all bar types.
