Date/Time: Fri, 03 May 2024 03:42:02 +0000
historical sc data stocks
View Count: 689
[2017-11-26 12:10:08] |
User492498 - Posts: 13 |
nxe.to (tsx) data is only loaded on a historical chart starting 2016-08-04. Chart settings - 'date range in file' is fixed at 2016-08-04 Data prior to 2016 isn't loading even though the stock was listed before 2016 and data as far back as 2012 is available (internet source). Increasing the number of days to load (chart settings) isn't working. Please advise on how to load an historical chart for nxe.to with data prior to 2016-08-04? This issue happens with several stocks. |
[2017-11-27 17:47:14] |
This means that is all the data that is available for the symbol. But we will check to see if there is anything we can do.
